Go Back   Home > Forums > General Interest > Car Audio
Old 3rd January 2010, 07:06 PM   #1
Robcrx is offline Robcrx  Canada
Robcrx's Avatar
Question What do leaky caps look like ?
Im in no way a tech guy, just curious. I found this pic online.
Are these caps starting to leak ?
Old 3rd January 2010, 07:34 PM   #2
No, the caps are manufactured with these marks.
Old 3rd January 2010, 07:51 PM   #3
event horizon's Avatar
With that type of can style capacitor you'll need to look near the base, where the cap is in contact with the PCB to see if they are leaking electrolyte.
Look for what could well be dried liquid or any form of liquid spill, if you can't see any you should be ok. This doesn't mean that the capacitors are still functioning as they should, just that they haven't "leaked" electrolyte The capacitance value could still be a country mile out due to age & heat.
"Never let your morals prevent you from doing what is right!" Salvor Hardin
Old 3rd January 2010, 07:55 PM   #4
These photos show a (defective) vented capacitor (on the right) and one that's intact.
Old 3rd January 2010, 11:46 PM   #5
Robcrx's Avatar
cool.
Old 4th January 2010, 12:44 AM   #6
One more. These are leaking from the bottom seal. There are two things that you need to look for. The brown liquid around the perimeter of the capacitor is where the electrolyte is highly concentrated. If you look out a bit farther, you can see that it looks like an oil has spilled on the board. It's more obvious on boards that are dusty but can be seen on clean boards if you look closely.
As a side note...
Anyone with an amp (Autotek, Hifonics...) that uses these brown Nichicon capacitors marked PF(M) should check for this to see if there is any leakage. The electrolyte can damage large areas of the board.
Old 4th January 2010, 01:00 AM   #7
Robcrx's Avatar
Ok cool.
Old 4th January 2010, 01:01 AM   #8
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
[QUOTE=Perry Babin;2034011].................These are leaking from the bottom seal. There are two things that you need to look for. The brown liquid around the perimeter of the capacitor is where the electrolyte is highly concentrated. ...........QUOTE]
Some manufacturers fix large caps down with with glue/cement. This can be brown or white. but usually goes up the can a little. Don't confuse with leakage.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 4th January 2010, 03:17 AM   #9
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
if there's a leakage, what's the best way to clean the PCB?
Old 4th January 2010, 03:20 AM   #10
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
liquid soap and water.....
leaky esl63's graeme uk Planars & Exotics 4 21st December 2009 03:00 PM
What constitutes a leaky Coupling capacitor? Drewaudio Tubes / Valves 5 23rd September 2007 06:33 AM
Leaky Caps? DreadPirate Parts 8 16th January 2007 02:02 AM
Leaky 9900 Revelator? mazdapowered Multi-Way 6 22nd November 2006 05:29 AM
what is a 'leaky' transistor? loonatron Analogue Source 8 17th March 2005 10:55 AM
Page generated in 0.09897 seconds (78.80% PHP - 21.20% MySQL) with 11 queries
