Go Back   Home > Forums > General Interest > Car Audio
Old 2nd January 2010, 11:06 PM   #1
Jonny Hotnuts's Avatar
Smile My 75$ Craigslist "box-o-amps"
I wasnt in the mood to buy any amps but I seen an ad on craigslist from a guy who purchased the entire inventory of a used audio store that was going out of business and was selling boxes of amps for 75$. The ad mentioned that they were not able to test the amps (found this was due to the volume of stuff they had). Heres a few things I got in my box, there were 2 crossovers and a processor made by carver KLW and a few more amps not worth picturing but here is the bulk.
BTW:
I lightly benched (with PS and no real load, just seeing if they worked). All the amps with the exception of the little Orion (haven't opened it up yet) worked perfectly. A few had rigged plugs that shouldnt be a problem to fix. The only one I was really concerned with was the LP....I tested it last and held my breath....with a click of a relay it came to life!!!
Here is a bad shot of the inside of the G&S Comp 100. This is also the same board used in the PPI made Sansui SM-1500 Sansui SM-1500 inside - Amp Guts except the Sansui is missing the DIN plug and 2 fets on the power supply.
I have so many amps now I dont know what to do.
Looks like I am going to put some on fleabay.
That is....all except for the 2202 (always wanted a TO3 amp!!!!)
~JH
Old 2nd January 2010, 11:38 PM   #2
Geek's Avatar
Such a deal!
Cheers!
Old 2nd January 2010, 11:42 PM   #3
InclinedPlane's Avatar
Orion is good stuff.
I must confess my favorite music is that made by the Rolls Royce Merlin.
Old 3rd January 2010, 12:11 AM   #4
Robcrx is offline Robcrx  Canada
Robcrx's Avatar
Score !
Old 3rd January 2010, 12:13 AM   #5
Not looking too good for the Orion.
Signs that someone else was 'messin'.
There were a few screws missing from the transistor hold downs, one screw missing from the board and a few caps that look stretched.
Old 3rd January 2010, 12:13 AM   #6
tsmith1315's Avatar
You done good Jonny!
Tim
Old 3rd January 2010, 01:08 AM   #7
Thanks all.....
After further observation on the 222 here is what I have found:
1. After pulling the foam tape off the caps the shrink tube is pulling off the bottoms of 2 exposing the cap base, and 2 are showing signs of mushrooming.
Please excuse my ignorance but I assume this means they are bad (even without testing).
2. Where the orange wire goes into the board there is a group of components that seem to have a puffy white corrosion around the base of the solder joints (in about a .75" circle). This includes all components localized....could this be from a liquid spilled on the board when someone else had it open or something more ominous?
My real question is now that with the caps that I clearly feel are bad is a very bad sign for the amp, meaning if these caps fail does it usually (*or always) mean that it chain reaction f's up much more?
From what I read people assumed that these SX series amps would play 1ohm mono like the HCCA just because it had Orion on the heatsink. (*the SX were supposed to be really nice amps when correctly loaded however)
Apparently many of them failed due to ultra low impedance loads.
Thanks for any advice
~JH
Old 3rd January 2010, 02:01 AM   #8
DaveM is offline DaveM  United States
DaveM's Avatar
Change out the caps if you are in doubt. It would be a shame to blow up speakers because of a couple bad caps. I would simply remove the devices with the corrosion and clean them up and re solder them. It can't hurt if you are careful and don't give anything too much heat.
Old 3rd January 2010, 02:51 AM   #9
spooney is offline spooney  United States
Awesome find! I'm extremely jealous. I can't pass up a good deal whether I need it or not
Old 3rd January 2010, 02:58 AM   #10
~Also....
Dont know if this means anything but the amp goes into protect on both channels when hooked up....at least WITHOUT speakers.
I hooked the amps up with no speakers attached and zero input to see if the amp starts. I dont know but I *could see an amp that would go into protect with the outputs being open. Because the amp went into protect as soon as the remote had voltage I didnt put speakers on it.
~This is my first Orion, and I dont know too much about them.
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
FS: 2 Tang Band W69-1042J 6"x9" Subwoofer: $75 + shipping zobsky Swap Meet 0 29th March 2009 05:16 PM
"Box" design and bracing for open baffle woofer array ryoshu Multi-Way 0 17th August 2008 06:07 PM
DIY "speaker box" ("BOOM BOX"). Help needed. MASantos Full Range 6 2nd September 2007 12:00 PM
replacing 12" sub in box with back speaker mounted 6" subs aussiebuddha Car Audio 7 14th October 2006 08:26 PM
Page generated in 0.10112 seconds (85.75% PHP - 14.25% MySQL) with 10 queries
