I read some of the post's you helped with.
Ok this is the first of 5 When powerd up amp sends 29.68 of dc out on left channel and 0.29 on the right. wondering what this might be?? |
#2 |
Does the left channel produce audio?
It sounds like you have shorted outputs or defective driver components in the right channel. You also need to check the 0.1 ohm resistors in the right channel.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Yes left channel produces audio but it throws the cone of the sub alomst out of the basket
#4 |
I'm sorry, I got the channels reversed.
Does the right channel produce clean audio?
#5 |
right channel is dead no output
#6 |
Do you have any shorted outputs or open 0.1 ohm resistors?
#7 |
the crazy thing is it saying the power supply fets are blown they are using
p60n06 for the fets and its saying they are shorted from leg1 to leg 3 |
#8 |
This amp isn't like other amps. The power supply FETs are driven by a transformer. The driver transformer's windings are connected across 1 and 3 on the power supply FETs.
#9 |
all the outputs are testing fine. Where are the 1 ohm resistors located? what are the color bands
#10 |
0.1 near the outputs. Brown black silver gold.
| MTX Thunder 2300 | spooney | Car Audio | 59 | 11th August 2010 12:52 AM |
| Help me fix MTX 152 and MTX 500D | hakentt | Car Audio | 94 | 8th December 2008 06:26 PM |
| MTX 2300 (bridged wrong) help! | subgeniusdude | Car Audio | 10 | 30th November 2008 04:01 PM |
| Mtx Thunder 2300 | vypr | Car Audio | 35 | 21st September 2006 07:35 PM |
| Page generated in 0.08699 seconds (77.17% PHP - 22.83% MySQL) with 10 queries |
