Go Back   Home > Forums > General Interest > Car Audio
Old 1st January 2010, 02:07 AM   #1
Default MB Quart RAA1000
I recieved this amp for reapir the power supply is totaly shot.
They are using FQP65N06's for the power supply fets. Wondering if i can switch theese to IRF1018 or do i need to stick with the originals.
The drivers are toasted also they are using KTN2907A and KTN2222A
Wondering can i sub theese for something else or if i need the same part numbers wondering where i can find them
Also the gate resistors are toasted i believe they are using 56 ohm
Any help would greatly be appericated
Old 1st January 2010, 02:28 AM   #2
I'd suggest that you go back with the originals.
The 2N2907 and 2N2222 are likely equivalents but the 2n2222 comes in a metal case.
http://datasheet.octopart.com/2N2222...heet-56639.pdf
If you have multiple gate resistors that read 56 ohms after removing the FETs, you're probably correct.
Help with MB Quart Speakers stax Multi-Way 4 30th November 2007 02:21 PM
FS: Scan-Speak 25W/8562 woofers/MB Quart MBM 50 S Mid-Range/MB Quart MCD 19E Tweeters Ballylongford Swap Meet 0 1st August 2006 06:20 AM
MB Quart Slinkylink Multi-Way 1 14th September 2005 12:56 AM
mb quart qsd216 tenderland Car Audio 4 31st July 2004 11:31 AM
Mb Quart MCD25 Radik Multi-Way 10 6th March 2004 04:16 PM
Page generated in 0.07337 seconds (67.92% PHP - 32.08% MySQL) with 10 queries
