Go Back   Home > Forums > General Interest > Car Audio
Old 30th December 2009, 06:06 AM   #1
Default jbl gtq 190
Im wonrking on this amp and it has me puzzled.
For the rectifiers it has a sf163a and a fep16bt in the board looks like the fep16bt is not orignal .
Wondering is the fep16bt = to a u1620?
And second thing is its sending the rail voltage to the speaker outputs
wondering if you can help me on this amp Any help would gretly be appericated
Old 30th December 2009, 06:45 AM   #2
Those rectifiers should work. An MUR1620 can replace the fep16bt but if it's not defective, there's no point.
Do you have negative rail voltage on the center leg of the sf163a?
Do you have positive rail voltage on the center leg of the fep16bt?
Old 30th December 2009, 06:58 AM   #3
i have + 31.86 on the u1620 had to replace the fep16 bt it was blown
and i have -26.11 on the other
Old 30th December 2009, 07:03 AM   #4
The voltages are not as close (in absolute value) as I'd expect. Place your black meter probe on a non-bridging speaker terminal and measure them again.
With the black probe on the same point, what DC voltage do you have on the power supply pins of the op-amps?
Old 30th December 2009, 07:11 AM   #5
u1620= 32.34
s= -26.18
i havent measured the op amps yet the power supply fets are getting red hot
Old 30th December 2009, 07:52 AM   #6
ok here are the readings sf163a= -26.18 mur1620= 32.34
lm318n
Pin1= -4.33
pin2= -6.28
pin3= - 5.03
pin4= -14.49
pin5= -3.62
pin6= -2.34
pin7= -1.61
pin8= -13.63
the other lm318n
pin1= -5.03
pin2= -8.33
pin3= -7.16
pin4= -14.58
pin5= -4.35
pin6= -2.32
pin7= -1.61
pin8= -13.88
Old 30th December 2009, 07:57 AM   #7
Are these in the audio section? If so, you should have positive voltage on pin 8.
Old 30th December 2009, 08:09 AM   #8
ok i have negative readings on all of the opamps so i checked the Mur1620 again and the new one i just put in is blown.
Wondering what might be causing theese to blow
Old 30th December 2009, 08:18 AM   #9
The rail voltage was OK so the 1620 must be OK. You need to find the regulators. I don't know the amp. Post a photo if you can't locate it.
Old 30th December 2009, 08:53 AM   #10
i saw some broken solder connections on the driver boards gonna fix them
Also there is a tlo74cn in the amp and that to has no positive voltage on it
The fets were hacked up but they still were good but a hack solder job so im gonna fix thoose nd fix the broken solder connections on the boards then go from there ill try to get my camera to take a decent pic of the amp cause all i see is the drivers for the outputs and on the driver boards just transistors like 2n something
Jbl 2123j spamhead57 Multi-Way 0 27th January 2009 03:37 PM
Jbl Le120h Hyldal Multi-Way 2 26th September 2007 09:25 AM
JBL L56's SuzieQ Multi-Way 0 7th August 2007 06:27 AM
Dayton 295-190 15" DVC RSBosma Subwoofers 4 18th February 2007 01:59 AM
Oscope Dumont 190 infinia Parts 3 9th March 2006 09:45 PM
Page generated in 0.09068 seconds (77.85% PHP - 22.15% MySQL) with 10 queries
