Go Back   Home > Forums > General Interest > Car Audio
Old 4th January 2010, 09:20 PM   #11
ok with the tester set on the buzzer function, the 3205's all switch as they should. When the tester leads are placed on a leg, it will beep and then stop, meaning it switched, and switch legs, and again will beep then stop until i switch legs again, back and forth. So all (4) 3205's are switching ok.
The 540's if i touch leg 2 + 3 they will switch, much faster than the 3205's, its a very small fast blip on the buzzer. But all seem to switch consistently although two of them seem to be not as responsive as the rest, but do switch.
The single RF2001T2D switches just fine.
The single FRH20A15 switches just fine.
Here is a shot of the board, I have highlighted where the different banks of transistors are.
The red are the 540's
The yellow are the 3205's
The blue are as follows:
1: 2SC3421
2: 2SA1358
3: 2SC3421
4: RF2001T2D
5: FRH20A15
Old 5th January 2010, 10:27 PM   #12
OK, I removed the once broken transistor and powered it up and I am sad to report, still a no go, same blank blinking display. Please let me know what I should check next.
Old 5th January 2010, 11:48 PM   #13
Have you tried to locate (or buy) a schematic diagram for the amp?
If there are no obviously defective components, this amp is going to be difficult (for me) to troubleshoot without a schematic diagram.
Old 6th January 2010, 06:13 AM   #14
no i sure haven't. Where could I find one?
Old 6th January 2010, 06:18 AM   #15
Consumer Electronic Parts and Accessories at PacParts, Inc.
68ECD2005
Old 10th January 2010, 07:09 PM   #16
jol50 is offline jol50  United States
I've had two of these line of alpines with issues in the small traces, one was in the bias circuit after I had replaced outputs and drivers and it didn't work. The issues they had were pretty mysterious until I found that. Anyway, I'd take a close look at the SMD side/areas and look for a blown trace its worth a try. The one was right at a thru hole I forget the other, and they were not obvious my magnifying desk lamp was very helpful. You might be good replacing what is blown, but just something to keep in mind and something you don't need a schematic for.
Old 11th January 2010, 10:58 PM   #17
I am still not able to find out what is blown on this amp. I honestly wish I could find someone local to my area who wouldn't charge me an arm and a leg to repair it as I am at a lose and rather upset that I took it out of the box and it worked fine for two days until it blew. Only problem is I bought it two years ago and just never had the chance to use it as I was deployed during the time so I can't return it.
Old 12th January 2010, 02:55 AM   #18
I just recieved a MRD-M300, the smaller version of what you have. I attached a picture of what I see for voltages. Yours will differ, but it should give us an idea of what you are missing.
The rectifiers should be 4 and 5 on your pic. Mine have a voltage of 22Vdc on them.
The power supply fets are at the bottom of my pic, yours are the 3205's.
cory
You cant see what I wrote for voltages. The four bottom components have
Pin 3 0Vdc
Pin 2 15.5Vdc
Pin 1 120mV
Rectifiers next two up
Pin 1 0Vdc
Pin 2 22Vdc
Pin 3 0Vdc
Old 14th January 2010, 05:24 AM   #19
thank you for the reply, I looked the board over very carefully but don't notice anything appearing to be blown. I will test the fets again on the Vdc and see what I get.
Old 15th January 2010, 02:58 PM   #20
Here is a photo of a bad trace:
Alpine mrd-m1005 schematics for repair Mr.Monkeys Car Audio 3 8th April 2011 10:01 PM
Alpine mrd-m501 Repair dj_square- Car Audio 2 31st August 2009 06:15 AM
Alpine MRD-605 no output cobology Class D 0 21st February 2009 01:45 AM
Alpine MRD-M301/JL 12W3V2 Tuning Help shagone Car Audio 6 6th May 2008 05:41 AM
Upgrade Alpine mrd-605? hc_TK Car Audio 1 5th April 2006 04:21 PM
Page generated in 0.11516 seconds (78.23% PHP - 21.77% MySQL) with 11 queries
