Go Back   Home > Forums > General Interest > Car Audio
Old 27th December 2009, 10:47 AM   #1
marko is offline marko  United Kingdom
Default headunit wired back to front? not working now..
simple question ( i hope!), what blows on a headunit if you wire pos and neg back to front? the ubit no longer powres up...
Old 27th December 2009, 10:51 AM   #2
Theres usually a diode behind the power connecter in the unit check that to see if its still good also check the board for open traces First things id check
Old 27th December 2009, 10:53 AM   #3
so it could be something really simple? i'm only used to working on amps!!
Old 28th December 2009, 05:38 PM   #4
jol50 is offline jol50  United States
I've fixed a small number of them, just follow the ground and power into it and you should find something blown right away. Most but not always that is all that is wrong, most put something there to protect it like a diode/etc that blows. Some of them have the power across the board though have to follow the trace then.
Old 29th December 2009, 12:08 AM   #5
If the unit was properly fused, it should have only blew a fuse. Have you used a volt meter to make sure the unit is getting power?
If it ain't broke Don't fix it
What's a bipole with front+back units? andyjevans Full Range 18 3rd December 2009 05:45 PM
horn speakers- back and front loaded Johnnyd Multi-Way 3 13th February 2007 02:40 PM
Port front or back?? SamClassA Multi-Way 4 8th November 2006 10:59 AM
Open back front horns mashaffer Multi-Way 3 24th June 2005 04:57 AM
Page generated in 0.07497 seconds (70.67% PHP - 29.33% MySQL) with 10 queries
