Go Back   Home > Forums > General Interest > Car Audio
Old 26th December 2009, 06:24 AM   #1
Default soundstream reference 1000 sx
When trying to power the amp up all i get is the two input over load light to light up
tested the fets all test fine wondering where i go from here?
Old 26th December 2009, 06:28 AM   #2
Does it produce rail voltage?
Old 26th December 2009, 07:22 AM   #3
Yes its producing rail voltage positive rail is 39.18 and negative is 37.10
The green power light is flashing
Old 26th December 2009, 07:36 AM   #4
Is the red LED switching on when the green goes off?
Are you sure that the outputs are not shorted? You have to check each one individually.
Are you sure that there are no shorted rectifiers?
Old 26th December 2009, 07:49 AM   #5
Ok there is no green light it wont light at all. the 2 red lights are solid when trying to power the amp up. I checked all outputs,power supply fets, and reflectors all test fine.
Wondering if i can pull one of the legs on the 317 and 337 or is it the 1620's to disable the output side to see if this amp will power up
Old 26th December 2009, 07:53 AM   #6
It would be simpler to pull the two legs of the inductor nearest the rectifiers.
Old 26th December 2009, 08:07 AM   #7
ok im stupid tonight u said pull the 2 legs of the inductor nearest the reflectors you talking the 2 nearest to the fep16ct's?
Old 26th December 2009, 08:10 AM   #8
Rectifiers, not reflectors.
Yes, near the FEP16s and FEN16s.
Old 26th December 2009, 08:19 AM   #9
ok must be in the power supply cause the amp still doesnt power up and red light are still on
Old 26th December 2009, 08:21 AM   #10
Is it producing rail voltage on the center legs of the rectifiers?
soundstream reference 300 mike49504 Car Audio 17 2nd January 2010 06:56 AM
Soundstream Reference 700s 0ldSch00lf00l Car Audio 4 3rd June 2009 11:26 AM
Soundstream Reference 604 Herb009 Car Audio 7 9th January 2008 08:52 PM
Soundstream Reference Class A 6.0 audiobahnkid592 Car Audio 0 9th January 2008 12:57 AM
soundstream reference 604 Bgun Car Audio 9 7th October 2006 04:24 AM
Page generated in 0.10838 seconds (77.54% PHP - 22.46% MySQL) with 11 queries
