Hifonics zeus gen x - Page 5 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 27th December 2009, 06:36 AM   #41
Pin 4 doesn't have any supply voltage. Follow the circuit back to see what's feeding that pin.
Old 27th December 2009, 07:22 AM   #42
what should i be looking for i traced it to a diode and that was ok but after that i dont know what usually feed it
Old 27th December 2009, 07:35 AM   #43
I would think it would go back to a transistor but it could be fed from the remote turn-on:
Remote -> diode -> pin 4.
On many amps, the op-amps used for the protection circuits are fed by the same circuit as pin 12 of the 494 so you should follow the traces to/from pin 12 of the 494 to see if there are any open traces between that circuit and pin 4 of the 324.
Remember traces can be on either side of the board and can pass under other components. It's possible for traces to open under those components.
Old 27th December 2009, 07:51 AM   #44
damn i lifted if off the board and traced it back to a tip 102 that is testing shorted ill replace that and then check the voltage
Old 27th December 2009, 08:20 AM   #45
ok no luck still 0.66 on pin 4. But the problem with the tip 102 is whoever worked on this amp before me fixed a broken trace and soldered it to the wrong leg on the 102.
after the diode the trace from pin4 goes back to a cap so ill lift it off then trace it back from there
Old 27th December 2009, 08:40 AM   #46
ok i replaced another tip102 in the amp and i think it kicked on but after 4 secs it will draw 60 amps of current so if i take out the fes16jt's will this disable the outputs to see if the power supply will start up
Old 27th December 2009, 08:58 AM   #47
Removing the rectifiers should completely isolate the audio section.
Have you re-checked the output transistors to see if any were shorted?
Old 27th December 2009, 09:20 AM   #48
ok i disabled the audio section . amp doesnt draw alit of current now. but theres still a problem in the supply theres only .69 on pin 4 of the 324 so i guess ill try to track it down later today .
Old 27th December 2009, 09:39 AM   #49
ok i think i found what drives pin 4 its an a1266 wondering if this can be crossed to something so i can see if i can get this amp running or do i need the 1266
Old 27th December 2009, 09:41 AM   #50
What PNP transistors do you have on hand?
hifonics zeus vii mike49504 Car Audio 6 30th April 2012 05:31 PM
hifonics zeus viii transformer... marko Car Audio 33 3rd January 2011 07:43 PM
hifonics zeus xi mike49504 Car Audio 68 12th February 2009 05:23 PM
Need help identifying an early hifonics Zeus jeclute Car Audio 4 5th June 2007 07:05 PM
Hifonics Zeus VII redimp Car Audio 1 20th December 2006 10:47 PM
Copyright 1999-2017 diyAudio
