Go Back   Home > Forums > General Interest > Car Audio
Old 25th December 2009, 04:35 AM   #1
Default pioneer gm5000t
im working on this amp and replaced the op-amps in it . The outputs are getting both positive and negative voltage.
But the right channel is dead I checked the drivers and both have the same reading on left and right channels so do the op-amps
wondering what to check next
Old 25th December 2009, 05:07 AM   #2
What do you mean by:
What readings?
Email me if you want the schematic diagram.
babin_perry@yahoo.com
Old 25th December 2009, 05:40 AM   #3
both op amps they are the 2068
Pin 1 0.4
pin2= 0.4
pin3= 0.4
pin4= -15.60
pin6= 0.4
pin7= 0.4
pin 8= 15.60
left channel is working right channel if u crank the source up u can hear music through the right but very low output
Old 25th December 2009, 06:28 AM   #4
ok i looked at the diagram and tryed a new 4558 and tested some more in the output section but still same problem
Old 25th December 2009, 06:44 AM   #5
You'll have to trace the signal through the amp. Is there no hope to get your oscilloscope working?
Old 25th December 2009, 06:59 AM   #6
dont think so i tryed to calibrate it again and when u calibrate it it should show a nice square wave but its not
Old 25th December 2009, 07:15 AM   #7
It may be a bad probe. Try calibrating it by using a small piece of wire to connect the cal signal to the input port.
Why did Pioneer do this? EchoWars Solid State 13 3rd June 2006 07:15 AM
Best out of a Pioneer... Radik Multi-Way 0 12th February 2003 01:05 AM
Page generated in 0.07948 seconds (72.90% PHP - 27.10% MySQL) with 10 queries
