The problem iim having is the right front channel distorts like crazy i put new op amps in check the outputs for the channel all seem fine i checked the drivers and they seem fine also wondering whats the next step?
#2 |
I know nothing about this amp. I may be able to help get it going but I'm going to need much better photos that on the ampguts site.
A scope would make the process much easier.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Back to this amp the right channels still disorts and everything is testing fine. wondering where i might go from here and what to check?
#4 |
Ok somemore checking into this amp. The amp has 4 op amps in it 1 for each channel.
3 of them measure 1=0 2=0 3=0 4= -14.79 5=0 6=0 7=0 8= 14.57 theese channels work perfect the left distorts channel the op amp reads 1=13.65 2=13.66 3=6.22 4=-14.38 5=6.22 6=13.70 7=13.70 8=14.56 is the op amp defective or do you think something is driving the voltage up on this ? |
#5 |
It appears to be defective.
Are pins 1 and 2 tied together? Are pins 6 and 7 tied together?
#6 |
pins 1 and 2 are tied together
pins 6 and 7 are tied together |
#7 |
If those pins are tied together and the output of the op-amp doesn't match the voltage on the non-inverting input of the op-amp, that op-amp is almost certainly defective.
#8 |
Unless this op amp is suppose to have thoose voltages or something else is blown i have the same reading on a new op-amp
#9 |
When an op-amp is used as a buffer (output pin and inverting input pin tied together) the output should match the voltage on the non-inverting input within a few millivolts. If it doesn't, the op-amp is almost always defective.
If the new op-amp has the same voltages, something connected to the output of the op-amp has to be driving voltage to the op-amp output. Are you 100% sure that you didn't accidentally reinstall the old op-amp?
#10 |
positive ill try another one just to be sure.
| Old Lanzar amp problem | skooter | Car Audio | 3 | 10th January 2011 07:54 AM |
| Lanzar vibe 266 | bobomohundro | Car Audio | 1 | 31st August 2009 07:25 PM |
| lanzar 50c problems | 67elcamino | Car Audio | 16 | 29th March 2009 12:50 AM |
| lanzar la670 schematics | onarush | Car Audio | 7 | 23rd June 2008 03:53 PM |
| Lanzar 600-S schematic | Diode | Car Audio | 0 | 22nd March 2003 01:39 AM |
| Page generated in 0.09944 seconds (77.99% PHP - 22.01% MySQL) with 11 queries |
