Go Back   Home > Forums > General Interest > Car Audio
Old 23rd December 2009, 06:43 PM   #1
Default Audiobahn 8000t
Im working on this amp. So far ive replaced all the power supply fets(irfz44)
Ive replaced all the 100 ohm gate resistors. Ive replaced the fet drivers.
Replaced all the outputs in the amp.
The reason is everything was smoked in the amp.
When i try powering it up the power supply fets on the side circled get red hot within 2 secs wondering where i go from here?
Old 23rd December 2009, 07:08 PM   #2
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
remove the fets, power up the amp and remote and check if the gates have square waves (or about 6V with a DMM from gate to ground)
Old 23rd December 2009, 07:47 PM   #3
That's a photo of an 8005. Are you working on the 8005 or the one in the photo below?
I agree, you need to check the gate drive signal. If the amp isn't drawing excess current, you may be able to check it with the FETs in the circuit (transistors tightly clamped to the heatsink). The voltage at the gate should be very near the voltage on pins 9 and 10 of the 494.
What did you use as subs for the drivers?
Old 24th December 2009, 01:52 AM   #4
one side of the fets the ones not getting hot from gate to ground 5.03 volts
The side the fets get red hot gate to ground 0.00 volts
Old 24th December 2009, 01:54 AM   #5
i used the original part number a1023 i found a couple new ones i had laying around
Old 24th December 2009, 02:08 AM   #6
Are you getting 5v on both pins 9 and 10 on the 494?
Old 24th December 2009, 02:15 AM   #7
4.98 volts on pins 9 and 10 of the 494
Old 24th December 2009, 03:06 AM   #8
That would seem to indicate that you have...
a shorted a1023
an open diode (parallel with the a1023)
a broken connection between the 494 and the gate resistors
Old 24th December 2009, 04:03 AM   #9
ok i replaced the 494 with one i had laying around now pins 9 and 10 read 0 volts
Old 24th December 2009, 04:04 AM   #10
Post the DC voltage on all 16 pins:
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
Audiolab 8000T no sound highviewvideo Solid State 2 19th October 2008 04:56 PM
Audiobahn sub skooter Car Audio 1 24th November 2007 04:21 AM
audiobahn spl on_chrome Subwoofers 1 23rd January 2006 05:35 PM
audiobahn A8002T pat99 Car Audio 1 11th January 2006 04:26 PM
Backlights on Audiolab 8000T tuner Baard Everything Else 0 26th May 2002 10:23 PM
Page generated in 0.11444 seconds (81.24% PHP - 18.76% MySQL) with 11 queries
