Go Back   Home > Forums > General Interest > Car Audio
Old 23rd December 2009, 05:50 AM   #1
spooney is offline spooney  United States
Default Which kapton(polymide) tape to replace insulators
I'm working on an earthquake d200hc mark 2(more of a restoration really) and i would like to replace the insulation tape that came on the amp as i poked a few holes in it trying to remove the fets from the heatsink. I know i've ordered kapton tape from McMaster-Carr before but i can't remember which kind i ordered. I was hoping somebody could chime in here and tell me what to buy. I'd hate to buy the wrong stuff and destroy this amp.
Old 23rd December 2009, 05:53 AM   #2
would this stuff work : http://www.tapecase.com/p.2528.644/1...ape-500-f.aspx
Old 23rd December 2009, 05:54 AM   #3
7648A34 at mcmaster.
Old 23rd December 2009, 05:58 AM   #4
thank you perry.
Old 23rd December 2009, 06:19 AM   #5
The tape you listed should work but I've never purchased from them.
The following ebay item is also good but it has to be cut to size which can be a pain.
160354064298
For those who find thread this after the auction has ended, look for Kapton MT under 'insulators' on the following seller's page:
eBay My World - jandrelectronix
Old 28th December 2009, 07:57 PM   #6
Does heat transfer better with one type of insulator as opposed to another? Are mica or silicone insulators superior or inferior to kapton tape?
Old 28th December 2009, 09:33 PM   #7
The Kapton tape is not the best insulator (with regard to the thermal transfer properties) but it's easily good enough for the power supply FETs (in all amps) and for the output transistors in class D amps. For the outputs in class AB amps, I'd probably use the Kapton MT instead of the tape but I've used the tape in plenty of class AB amps with no problems.
'Thin' mica insulators are probably better than the Kapton but they're a pain to deal with when there are a lot of transistors.
Metallic insulators are probably the best but are expensive.
The silicone insulators vary quite a bit. Different materials will have different transfer characteristics. Their performance also depends on the pressure applied (typically, more pressure = better transfer). If you can find the material to use as a replacement, it's likely to be expensive.
The Kapton tape and the Kapton MT are essentially all I use.
Old 23rd March 2010, 04:23 AM   #8
I just bought some of that kapton MT from ebay and I did not realize that it didnt have adhesive on it. Do you use anything to secure it down Perry other than the fets themselves?
Old 23rd March 2010, 05:13 AM   #9
There's no need for an adhesive. The heatsink compound will hold it in place well enough until you get the transistors clamped down on it.
WTB: Kapton or Mylar tape sonidos Swap Meet 6 4th September 2009 02:50 AM
How to glue Kapton? Wavebourn Planars & Exotics 10 17th December 2008 04:29 AM
Kapton tape Speeed3 Car Audio 10 8th May 2008 07:29 PM
Kapton tape instead of insulators? spooney Car Audio 1 7th November 2007 09:24 PM
Kapton Tape problems valterdaw Car Audio 9 26th September 2006 11:39 PM
Page generated in 0.10237 seconds (77.23% PHP - 22.77% MySQL) with 10 queries
