rockford fosgate power 650 mosfet
Old 20th December 2009, 08:42 PM   #11
Perry Babin is offline Perry Babin  United States
Are you sure that the 540 isn't defective?
Are you sure there are no solder bridges? Clean the area thoroughly and look at it with a high power lighted magnifying glass.
Old 6th January 2010, 04:02 AM   #12
mike49504 is offline mike49504  United States
Ok back to this amp it kept blowing the outputs in it everytime i replaced the bad one and the two beside it. I replaced all of the outputs, all the drivers,all the opamps, and a couple resistors and 2 caps.
My next question is should i check anything else in this amp before putting it back in the sink and powering it up?
Old 6th January 2010, 04:22 AM   #13
Do you have a 2 ohm current limiting resistor?
Old 6th January 2010, 04:32 AM   #14
i stopped over at my friends shop and all he had was a 1.8 ohm but i grabbed it from him
Old 6th January 2010, 04:43 AM   #15
With new outputs, drivers and fuses in the defective channel and all transistors clamped down. measure the DC voltage with the black probe on leg 3 of the outputs and the red probe on leg 1 of the same output. Do this for all 6 in the defective channel and post the voltages.
Of course, have the current limiting resistor in the B+ line.
Old 6th January 2010, 05:08 AM   #16
i couldnt test them all but the ones i did test read - 3.54 between legs 1 and 3
The reason i didnt test them all is because the 1.8 ohm 5 watt current limiting resistor got so hot it was smoking like crazy
Old 6th January 2010, 05:10 AM   #17
Test a few at a time. Let the resistor cool in between.
Did you set the bias fully counter-clockwise after replacing the outputs and drivers?
Old 6th January 2010, 05:18 AM   #18
irf540 0 volts between legs 1 and 3 . 9540 1.65 between 1 and 3
other channels 540 - 3.54 9540= 2.70
Havent turned any bias pots down which ones are they in this amp?
Old 6th January 2010, 05:27 AM   #19
The two circled in the photo and the other two in that area (didn't have a photo showing all 4). Turn the one nearest the channel that's failed.
Old 6th January 2010, 05:28 AM   #20
Has the same output in one particular location failed repeatedly?
rockford fosgate power 650 mosfetHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
repair of rockford fosgate power 451s chemid51 Car Audio 10 26th December 2009 08:34 AM
Rockford Fosgate/Mosfet steven123654 Car Audio 5 2nd September 2009 02:13 AM
Rockford Fosgate Power 800.4 lostamps Car Audio 6 2nd January 2008 12:21 PM
