punch 150hd PS fets - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 16th December 2009, 02:37 PM   #1
damage is offline damage  United States
Default punch 150hd PS fets
Can I replace the 6 ss264 with 4 irf540n or irf540? If not, what is the best substitute?
Old 16th December 2009, 05:09 PM   #2
For the power supply, an IRFZ44 would be a better sub than the IRF540.
Old 16th December 2009, 07:43 PM   #3
Should I use 4 or 6? It seems with the much higher current rating I could use 4.
Old 16th December 2009, 07:51 PM   #4
Use 6.
Old 16th December 2009, 08:07 PM   #5
ok thanks!
Old 18th December 2009, 12:06 AM   #6
Do I replace the BUK455 outputs with IRF540?
Old 18th December 2009, 12:17 AM   #7
The IRF540 is rated for less current but is likely a good sub. If you're ordering the FETs from Mouser, order the IRF540A.
Old 18th December 2009, 12:32 AM   #8
I have some IRF540Ns. Those seem to be working. However, I see the BUK455 is rated at only (100A) 18A@100* while the IRF540 is rated 20A@100*.
Old 18th December 2009, 12:43 AM   #9
This is the datasheet I referenced. Maybe the FETs are not the same. You didn't have the -100a in the previous post.
http://datasheet.octopart.com/BUK455...eet-536703.pdf
The 540n is rated for 33 amps. The 540 is rated for 28 amps. I've seen the 540n do some strange things in the later Rockford amps so I recommend against using them (for people who have to order parts) but if they're working OK in your amp, they should be reliable.
Old 18th December 2009, 01:54 AM   #10
That's the problem with these old amps I am finding... reliable datasheets are hard to find. Thanks!
RF Punch 150 chipper Car Audio 8 24th September 2009 01:08 AM
Selling a punch 250a2, old punch 75, and ppi epx 205 on EBAY ppia600 Swap Meet 0 23rd February 2008 02:17 AM
Punch 800.2 meepers Car Audio 26 16th January 2008 10:32 PM
RF Punch 75.2, help plz JSmooth420 Car Audio 5 17th September 2006 11:20 AM
My experience: the cheap punch set VS Greenlee punch vax9000 Tubes / Valves 5 21st July 2006 08:52 PM
Copyright 1999-2017 diyAudio
