Power supply is good and I have modulation at output fets. can't seem find my low voltage for opamps or their source for it.
...............I Hear in color................. |
#2 |
What is the DC voltage on the NJM3403 nearest the RCA jacks? Place the black meter probe on the chassis ground terminal of the amp.
Pin 1: Pin 2: Pin 3: Pin 4: Pin 5: Pin 6: Pin 7: Pin 8: Pin 9: Pin 10: Pin 11: Pin 12: Pin 13: Pin 14:
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Pin 1:5.79
Pin 2:5.80 Pin 3:5.80 Pin 4:10.32 Pin 5:5.72 Pin 6:5.80 Pin 7:5.80 Pin 8:5.80 Pin 9:5.80 Pin 10:5.72 Pin 11:.002 Pin 12:5.75 Pin 13:5.79 Pin 14:5.79 These are the voltages as you requested.
#4 |
The voltages are just about what I'd expect. There's no missing supply voltage.
Have you tried tracing the signal through the op-amps?
#5 |
Yes I have and found no signal, no output. And what actually supplys the low voltage supply,I cant seem to see any 7815's or zeners or drop voltage resistors. I guess i will check my pots next. Any common problems associated with this amp you are aware of off the top of your head.
#6 |
I don't remember having any problems with the preamp section.
For some of these amps, the positive supply is connected to the 12v source. There is no negative supply. The negative supply pin is tied directly to chassis ground. The signal is biased to ~6v. If you don't have signal on pin 1 of the 3403, you may have broken connections on the RCA jacks.
| earthquake amp t200/4 | steliosssss | Car Audio | 2 | 12th June 2009 03:24 PM |
| Earthquake schematic | junglejuice | Car Audio | 0 | 19th May 2008 03:10 AM |
| Earthquake UHC2020 | Puggie | Car Audio | 0 | 2nd August 2006 09:09 AM |
| -:- Earthquake -:- | audioPT | Subwoofers | 3 | 30th October 2004 01:02 PM |
| dead 2kw earthquake amp | kgrant | Car Audio | 9 | 15th September 2003 01:20 PM |
| Page generated in 0.07238 seconds (76.51% PHP - 23.49% MySQL) with 10 queries |
