Im working on this amp and something strange is going on . If you have the switch on two channel input all 4 channels work fine. Then if you switch it to 4 channel input only 3 channels work -- left front channel is dead. Wondering what might cause this??
Any help would greatly be appericated |
#2 |
Email Rockford for the schematic diagram.
A defective switch, RCA jack or op-amp could cause it. The switch or jack would likely be intermittent. A defective op-amp may get significantly hotter than other similar op-amps (those with the same part numbers). You can also compare the inverting input to the non-inverting input on each op-amp used for audio. Those two inputs (for each half of each individual op-amp) should have essentially the same voltage (±0.020mv DC -- approximately).
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Ok i found that the rca jack was loose resolderd it. Also theres a burnt trace in the power supply section But the amp still works it. It popped the trace on both sides of the board near the caps Wondering if you might know why this is??
#4 |
I don't know what caused it to burn. Several people have emailed me with similar problems. Generally, they repair the trace and the amp works. If you determine what caused it, post it here.
| Rockford P4004 Terminal blocks | brandes.cm | Car Audio | 6 | 15th November 2009 04:35 AM |
| Rockford fosgate 800a2 | fongman | Car Audio | 39 | 28th February 2009 08:35 AM |
| Rockford Fosgate 325.1 | phreaktor | Swap Meet | 1 | 28th February 2008 11:54 PM |
| New Rockford Fosgate amp. $50.00 | NerdMike | Swap Meet | 0 | 4th March 2005 11:57 PM |
| Page generated in 0.06605 seconds (71.82% PHP - 28.18% MySQL) with 10 queries |
