Which is best for subwoofer use?
I have four Rockford Fosgate Punch amps all withing 100 watts i suppose?
i have a two Pucnh 55.2's
and one punch 40.2 and one punch 100z2
Since these are all i can afford (when you work at dollar tree) lol
I'm guessing a Punch 55? How does the Punch 40.2 do? is that amp pretty strong to push an Rockford Punch XLC 12 4 ohms. My 55 pushes it pretty good. But i've never owned a Punch 40.2?? I also have a Punch DVC 12.
I need some system design help. I'm putting it in a 94 honda civic coupe.
The 40 is just as good as any other Rockford product. They have only made one amp with less power. You really need to consider using your DVC woofer, if it is a dual 4 ohm, and using both of the 55s.
Oh yeah i forgot to mention that one of my Punch 55s is partially working. The left channel doesn't play. I got it to work because the input was blown up. Or what if i wire it to 8 ohms?
