Hi there,
I have rubicon 204 amp., it doesn't start normally. It starts after ~30 min. when I turn on him and works erratic (1 sec works 2 sec doesn't work, etc...) Sometimes starts and works OK. So, where could be a problem ? |
#2 |
Post the DC voltage on all of the pins of the SG3524 when it starts normally and when it refuses to start. Place the black meter probe on chassis ground. Place the red meter probe on the point where you need to measure the voltage.
Working properly Pin 1: Pin 2: Pin 3: Pin 4: Pin 5: Pin 6: Pin 7: Pin 8: Pin 9: Pin 10: Pin 11: Pin 12: Pin 13: Pin 14: Pin 15: Pin 16: Fails to start Pin 1: Pin 2: Pin 3: Pin 4: Pin 5: Pin 6: Pin 7: Pin 8: Pin 9: Pin 10: Pin 11: Pin 12: Pin 13: Pin 14: Pin 15: Pin 16:
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
PB, thanks for the schematic.
I have found similar issue in the post : SoundStream Rubicon 1002 Turn-On Delay I'll try to change cap C158 firstly. |
#4 |
This issue solved. I have changed the cap and now amp starts normally. But I noticed that where the reference voltage should be +15V and -15V, I have +14,8V and -15,2V, is it ok ?
| SoundStream Rubicon 1002 Turn-On Delay | kds9591 | Car Audio | 11 | 26th March 2012 11:47 PM |
| Soundstream Rubicon 702 Issue | Lobby Ludd | Car Audio | 4 | 24th September 2008 06:21 PM |
| Soundstream Rubicon 702 Output transistor Problem? | tyu527 | Car Audio | 10 | 29th August 2008 06:37 AM |
| Soundstream Rubicon 805 | audiobahnkid592 | Car Audio | 16 | 23rd July 2008 10:13 PM |
| Sub channel not working on Soundstream Rubicon 555 | gti16vman | Car Audio | 5 | 20th May 2008 07:20 PM |
| Page generated in 0.08148 seconds (68.27% PHP - 31.73% MySQL) with 10 queries |
