Go Back   Home > Forums > General Interest > Car Audio
Old 20th November 2009, 03:04 AM   #1
de hero is offline de hero  Trinidad and Tobago
Default Will using my 5 channel as a 4 channel wreck channel 5?
I was planning on using a second 5 channel amp in my car (An older Hifonics Zeus z700) to allow me to go 3 way front active. I would have bridged channels 1 and 2 as well as channel 3 and 4 to put 110 RMS a side to my mid bass speakers.
But my friend who does installs said that there is a very high likelyhood that this course of action will result in the unused subwoofer channel (channel 5) eventually "dying".
He explained that there are no warning signs but "whenever" you attempt to put the amp back into 5 channel use the sub woofer channel will not function. Qualifying his statement somewhat by saying that it could take three months or so for the damage to be done.
Can anyone confirm if there is a logical reason for this and if so can I do anything to prevent it?
Thanks.
Old 20th November 2009, 03:29 AM   #2
That will not damage the amplifier.
If it ain't broke Don't fix it
Old 20th November 2009, 05:37 AM   #3
jol50 is offline jol50  United States
I've never heard of that one. If you have no speaker connected, then no current flows through the outputs. I can't see how that would damage anything. I've had sub amps in cars where I took the box out to travel and I didn't unhook anything, so the amp was on because I never shut the radio off. Most 5th ch are basically another amp internally, because they usually have higher voltage than the other channels so they must have their own power supply. Some newer ones are class D in the sub section like my kicker. I ran it not using the 4ch part for a while and it worked ok, but it did get some strange feedback noise between tracks from the CD player while I did. But it was minor and eventually I got the other stuff installed and hooked up the 4ch then it went away.
Old 20th November 2009, 09:26 PM   #4
tsmith1315's Avatar
Add one more to the consensus -it won't cause any problems.
Tim
Old 21st November 2009, 10:52 PM   #5
ppia600 is offline ppia600  United States
Zero problems
Don't worry... you can always turn the gain down!
Old 22nd November 2009, 10:25 AM   #6
So we are unanimous then!! Thanks everyone..
Creating 5.1 Multi Channel sound from 2 channel jenkrich Everything Else 5 1st September 2009 08:29 AM
4 channel conversion to mono 1 channel iUSERTLO72p Car Audio 24 25th October 2007 06:07 PM
HELP!: Channel volume very very low, other channel fine. harrisni Solid State 2 20th September 2006 12:10 PM
My 4 channel car Amp distorting on 1 channel (large pics) MikeHunt79 Car Audio 9 3rd September 2003 07:41 AM
Help quick! 4 Channel > 2 Channel? zmoz Car Audio 3 5th July 2003 09:48 PM
Page generated in 0.09168 seconds (72.53% PHP - 27.47% MySQL) with 10 queries
