Go Back   Home > Forums > General Interest > Car Audio
Old 14th November 2009, 09:50 PM   #11
Thanks for all the input and help. 4 of the 6 caps, 47uf 50volt were all blown. I removed all 6 and cleaned up the mounting holes with desolding braid. I found 5 47uf 50 volt caps and that was all they had, so I bought one 47uf 63 volt and installed them on the board. Do you think the 63 volt cap will cause any trouble? Hooked it backup in the car with the cover off so I could watch the board to see if I was going to have any more trouble and it is working great without any smoking now. That coil seems to be working fine without any shorting so I am gonig to leave that alone. Thanks again for the help.
Old 15th November 2009, 06:15 PM   #12
It would have been better to have the caps matched but if they're the same value, it probably won't cause any problems.
Sometimes, the inductor only shorts after the cover is reinstalled and pressure is applied. It's possible that, if it was shorted, you moved it enough so that the bare points on the windings won't match up again. If it blows the caps again, you'll need to check the inductor and insert an insulator between the windings.
Old 15th November 2009, 06:16 PM   #13
Cool! glad to hear its working out for you.
Perry your correct I was thinking of the another older silver 705 model...So many amps over so long of time lol sometimes it runs together upstairs lol lol THX Perry
Zen V4 Smoking Q5 Diomedian Pass Labs 6 15th November 2005 02:46 PM
amp smoking biznatcher Car Audio 5 13th September 2004 11:48 PM
Smoking Amp jkramer Solid State 15 28th August 2004 04:17 PM
Smoking Amplifier jkramer Solid State 0 23rd August 2004 02:37 PM
DOZ smoking? Kari Solid State 8 1st February 2004 02:40 PM
Page generated in 0.06592 seconds (68.78% PHP - 31.22% MySQL) with 10 queries
