#11 |
It isn't fun unless it can kill you! |
#12 |
The 20 pin IC looks like a HIP4080(A).
The Monacor Carpower D-REX 1200 (probably only sold in Europe and now discontinued) looks like a renewed version of that amplifier design, with some size reduction (a single bigger supply toroid) and migration to SMD. I find a lot of similarities in parts and overall layout, including the "black-box" potted daughter PCB.
I use to feel like the small child in The Emperor's New Clothes tale |
#13 |
Except for the color of the board, this appears to be essentially identical to the old Planet Audio PA2500D.
All 3 of the inductors in the upper left of the photo tend to short. When you get the amp working and have all of the power transistors tightly clamped to the heatsink, you'll need twist them gently to see if there are any problems. If you see sparks between the windings or if the amp begins to draw more/less current when twisting them, they have intermittently shorted windings. You should do this with a 2 ohm current limiting resistor in series with the B+ line. If the inductor just in front of the black box has shorted windings, it could cause enough current to damage the power supply. If you don't have a current limiting resistor, insert a 10 amp fuse in the B+ line. If none are shorted yet, you need to apply a few drops of an good adhesive like Goop to the terminal windings. Apply it at the top and let it drip down the side of the inductor between the terminal winding and the rest of the windings. This will help prevent them from shorting in the future. If any of the audio FETs shorted when they failed, you'll need to replace the 4080. They virtually always fail when the FETs short.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#14 |
Ok so far the supply is all good.. Just got those parts in today.. I'm waiting on the outputs from future.. So i will post what happens when I have everything in place..
Oh and I did replace the 4080 just to be sure..
#15 |
Ok amp works perfect.. Thank you Perry and Eva.
| Le class A and Le monstre parts sell off | danieljw | Swap Meet | 22 | 5th June 2010 10:27 AM |
| simple class a amp with minimum parts | slr 5000 | Solid State | 41 | 12th January 2010 09:30 PM |
| Recommended suppliers of kits, modules or parts for Class D | The golden mean | Class D | 0 | 6th October 2007 02:04 PM |
| SMPS and class D parts | gearheaddruid | Swap Meet | 0 | 31st January 2005 06:08 AM |
| harris semi class-d switching amp and parts | fermatsEnigma | Swap Meet | 1 | 6th February 2004 02:25 AM |
| Page generated in 0.09477 seconds (73.32% PHP - 26.68% MySQL) with 10 queries |
