Help fix amp - rail voltage gone crazy
Old 13th March 2012, 05:11 PM   #41
manina is offline manina  Germany
I measured all resistors are are within specs.
The voltage at the emitter is equal between the 4388 of the same side.
While I was measuring, I also adjusted the idling current as detailed in the service manual.
The good news is that the amps seems OK now - it has been up and running for 10 mins without any temperature excursion and stable current draw.
On the other hand, there is a significant difference between the two channels for what concern the emitter DC:
4 mV and 7 mv on the left channel
15 mV on both 4388s of the right channel
Old 14th March 2012, 12:41 AM   #42
Perry Babin is offline Perry Babin  United States
Did you try swapping the emitter resistor to see if the problem followed the resistor?
How accurate is the meter at low resistance?
Old 14th March 2012, 08:28 AM   #43
No - I have not yet swapped the emitter resistor but I can try this as well.
The meter is a fluke 77 - not sure how accurate it is.
Old 15th March 2012, 07:57 PM   #44
I did few swaps of the emitter resistors without seeing any major changes.
On the other hand, I kept the amp running for nearly 3 hours without any issue. At this point, I'll use an old rule "if works, don't touch it!"
Help fix amp - rail voltage gone crazyHide this!Advertise here!
Simple voltage regulator get crazy... and so am I Malefoda Power Supplies 12 18th August 2009 10:38 PM
max rail voltage? MikeFarad Chip Amps 4 11th August 2007 09:44 PM
A40 Rail Voltage gpsmithii Pass Labs 29 19th April 2006 05:01 PM
Rail Voltage to Capacitor Voltage Mermprin Parts 6 20th September 2004 03:56 PM
Rail voltage compared to transformer voltage SteveG Solid State 4 22nd July 2002 11:50 PM
