Im working on a directed 500/2 amp one of the mosfets was bad also a output was also bad. So i pulled both bad parts from the board and replaced the tl494 in the amp. When the amp is powerd up the power light just blinks every few secs wondering what i should check at this point
#2 |
Do you see a pulsing of DC on the bridging speaker terminal of any channel as the amp tries to power up?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
How do i check that agin sorry been awhile since i worked on amps So wondering how do i check to see if i have pulsing dc on the bridge terminals
#4 |
If you have a scope, simply touch the probe to the speaker terminals. If you're using a multimeter, touch one probe to a non-bridging speaker terminal (any one) and touch the other probe to the various bridging terminals as the amp tries to power up.
#5 |
i checked and yes it does have pulsing dc on the terminals
#6 |
I expected it on one, possibly. Do you have DC on all of the channels?
Did you use a meter or a scope?
#7 |
I used a meter and only have pulsing dc on the left channel nothing on the right channel
#8 |
Did you check or replace any of the output transistors in that channel?
#9 |
i checked the outputs in that channel one of the tip35c's was bad so i took it out but havent replaced it yet thought maybe i could power the amp up without it being there to see if anything else was wrong
#10 |
If it has more than one TIP35 in that channel, you can remove the defective one and the amp should operate normally if there are no other problems.
Did you check the driver transistors (for both the 35s and 36s) in that channel?
| Viper (Directed) d1200.1 Supply Fet Problem | amc32 | Car Audio | 13 | 1st January 2009 04:14 PM |
| Sub channel not working - Directed 1100d5 | CanadianDream | Car Audio | 8 | 12th December 2008 06:27 PM |
| directed 1500d | mike49504 | Car Audio | 30 | 20th November 2006 02:43 PM |
| this question directed to skinnyboy | albooogie | Car Audio | 17 | 7th February 2004 08:37 AM |
| Directed 500 Amp for sale | squosh69 | Swap Meet | 0 | 29th January 2003 10:14 PM |
| Page generated in 0.09235 seconds (72.48% PHP - 27.52% MySQL) with 10 queries |
