Go Back   Home > Forums > General Interest > Car Audio
Old 6th November 2009, 03:43 PM   #11
yes i checked all the drive transistors in each channel all check good
Old 6th November 2009, 08:03 PM   #12
Pull all of the output transistors from that channel and check them on ohms and on diode check to see if any are leaking.
Old 6th November 2009, 09:47 PM   #13
Thanks Perry i pulled the otputs and checked them i was leaking amp powers up fine now so when i get the new parts and install them ill let u know how the amp works
Old 7th November 2009, 02:38 AM   #14
i replaced all the outputs and powerd up the amp it played fine for 10 mins the smoked the output transistors again . Wondering what might cause this
Old 7th November 2009, 02:44 AM   #15
Did you replace them with the same exact part number?
Are you sure the outputs were flat and tight against the sink?
Are you sure the insulators were in good condition?
Viper (Directed) d1200.1 Supply Fet Problem amc32 Car Audio 13 1st January 2009 03:14 PM
Sub channel not working - Directed 1100d5 CanadianDream Car Audio 8 12th December 2008 05:27 PM
directed 1500d mike49504 Car Audio 30 20th November 2006 01:43 PM
this question directed to skinnyboy albooogie Car Audio 17 7th February 2004 07:37 AM
Directed 500 Amp for sale squosh69 Swap Meet 0 29th January 2003 09:14 PM
Page generated in 0.07816 seconds (71.78% PHP - 28.22% MySQL) with 10 queries
