Go Back   Home > Forums > General Interest > Car Audio
Old 10th November 2009, 06:12 AM   #21
TO-3 is offline TO-3  Peru
TO-3's Avatar
Send a message via Yahoo to TO-3
Originally Posted by Perry Babin View Post
Are you sure the bias was 0.7v instead of 0.007v or 0.0007v?
1mv across the resistors should produce clean output across the spectrum.
If I said the bias could be set without having the amp clamped to the sink, I was wrong.
Oh man, good catch. I meant 7mV. And I guess I did mis-state you. Sorry, Perry.
I used to set the bias on those without the sink, but obviously you can't keep them running like that for long. With the bias-jumper in place, no problem.
For some reason this is not letting me edit my last post.
Check out Tube Driver BLUE products at: www.tubedriver.com
Old 10th November 2009, 09:49 AM   #22
So, if this is correct, we have:
I=Ure/Re=0.007/0.165=42.4mA bias current per transistor.
We have 20 transistors, supplied with 60v.
Itot=20*0.0424=0.848A - Total standby current drained from PSU (+/-60v)
Ptot=Ucc*Icc=60*0.848=50.9W - total standby power only from ouput transistors.
Lets transfer this power into the other side of PSU (12v), if we have 80% efficiency:
Pin=Pout/0.8=50.9/0.8=63.5W - power drained from 12V accu.
Iin=Pin/Uin=63.5/12=5.3A - Current drained from 12v accu only for Output transistors.
In my amp, now, with NO bias current to power transistors, I have 2A cirrent drain from accu. This means, so we have 2A additional current from other part of the amp. (Drivers stage, preamps, and so.).
Iintotal=5.3+2=7.3A Total Current in standby mode from 12V accu.
But this is almost 2.5 times more than specification in user manual, where is written - standby current 3A.
In this way, If I want to have 3A standby current, I need 8mA bias current or about 1.3mV on emiter resistors (2x0.33ohm in paralel)...
Old 10th November 2009, 10:42 AM   #23
I don't think the 3a idle current is a precise specification. I'd suggest that you set it to ~1mv across the emitter resistors and check it for distortion. If it's clean, across the audio spectrum at low level as well as at full power, I'd consider it done.
Old 10th November 2009, 11:32 AM   #24
Yes, 3a idle current is not a precise specification of course... It depends from many things... Input voltage, temperature, ... I checked the distortion on oscilloscope, and even now, in class B, they are vary small... specialy in low freq. and high power, where this one will be used . Probably Negative Feedback and transistors are fast enough.
But I agree with about 1mV across emiter resistors. It should be enough.
BTW, I'll try to measure this from one other amp. - the same model...
Then I'll post the results. I hope this other amp. to be original one (means not repaired, tuned, and so...).
Old 10th November 2009, 05:46 PM   #25
Hey Jon, THX for jumping in with some spec numbers.
My worry is the lower rail supply regulator devices cooking off as they instantly have a rather large drop across them regardless of the idle bias settings... Thx for your input as always.
I also re-check the amp for stability over time so clamped to the sink is the only way i do any testing and setting on these big boys from the day... And I do try to stay near factory idle spec's as rule unless i find other issues limiting the amp I would rather not high bias any car amp that will sit someones trunk at 140+ degrees. Turned on outputs that play to spec 20 to 20K are just fine for me IMO...Any more is just asking for heat related troubles finding their way back to my bench....
Good catch Perry as always your on the mark.....
Old 18th November 2009, 03:49 PM   #26
So, We measured another PC2350, and result is the same. No bias current, total driain current from accu (12v) is 2A. Exactly the same with my amp. Ube of the power transistors is less than 20mV. (About 11mV) - Again Class B.
Old 19th November 2009, 08:24 AM   #27
Staykov is offline Staykov  Bulgaria
PPI with new caps.
http://img200.imageshack.us/img200/5306/p1020459r.jpg
http://img200.imageshack.us/img200/5087/p1020452j.jpg
http://img200.imageshack.us/img200/1818/p1020458i.jpg
P.S. TO-3 , thank you for your help.
next amps for upgrade will my favorite Butler TDB2150&TDB475
N.E.W. A-20 amp service manual or schematic alaskahiatt Solid State 4 18th May 2011 12:30 AM
DACMagic II Schematic/Service Manual spikeymikey Digital Source 4 13th December 2006 05:40 PM
pm78 schematic or service manual Luke Solid State 20 18th March 2006 03:20 AM
akai am-52 service manual or schematic bmwdriver325i Solid State 1 1st May 2005 03:20 PM
Page generated in 0.12087 seconds (80.49% PHP - 19.51% MySQL) with 11 queries
