Go Back   Home > Forums > General Interest > Car Audio
Old 3rd November 2009, 04:38 AM   #1
Default kicker zr 600 problems
i have an old zr 600 amp and heres the story. when i first got it the amp wouldn't put out sound at all, it had some crazy box that plugged into the crossover slot so i opened the box and there was 2 crossovers inside it so i tied both directly into the amp, one did nothing, the other would play quietly, then make the subs start to flutter violently, after sitting it in my basement for about a year i tried it again, now it blows fuses if the gain is tuned up at all ( as soon as it tries to "flutter" the subs). is this a problem with the crossover or is it a problem with the amp? it's hard to find a new crossover cause the amp's from the 90's, and i bent and broke the 80htz chip that presses into the crossover so i don't know what to do now. any help would be appretiated, i am not a pro so i don't know proper terms to part names. thanks in advance.
Old 3rd November 2009, 12:33 PM   #2
There is a blown surface mount fuse somewhere between the shield of the RCA input jack and the non bridged speaker wires. Following is a picture of a Kicker amplifier with the fuse. The fuse is labeled TH. In the amp in the picture, the fuse is mounted directly below the RCA jacks. Some amps have the fuse on top of the board. Picture courtesy of Perry Babin. He can probably tell you exactly where the fuse is located on your particular amp.
If it ain't broke Don't fix it
Old 4th November 2009, 04:57 AM   #3
The previous post is likely correct. Do you read near 0 ohms between the shields of the input RCA jacks and the non-bridging speaker terminals?
If not, the fuse or a trace is likely open.
Old 6th November 2009, 02:24 AM   #4
i wasn't quite sure where the fuse was located but i'll check it out and get back to you.
Old 6th November 2009, 03:48 AM   #5
Check Ebay for the x-over cards, there is always some on there.
Ben
Kicker 600.1 mike49504 Car Audio 3 25th March 2009 05:10 PM
kicker DX700 problems ben04srt Car Audio 9 18th January 2009 11:05 PM
Kicker L5 in a 1.75 box skooter Car Audio 4 16th October 2008 02:54 AM
Kicker L7 skooter Car Audio 5 26th September 2008 12:36 AM
Kicker 500 si stormtrooper Car Audio 0 25th September 2006 02:20 AM
Page generated in 0.07572 seconds (70.45% PHP - 29.55% MySQL) with 11 queries
