#21 |
Hi Tim
Yes, quite shocking. I wrote to Kicker Technical Dept and they in fact agreed with me that this is the only model that can be used for IB. I don't really know the reasons for the wide discrepancies. I have made a copy of the manual that is included with the C15. Shows the full T/S of different models. For comparison, below is the full T/S with LMS. Model = KICKER C15 Re (ohms) = 4.52 Zmax (ohms) = 50.73 Fo (Hz) = 23.71 Qms = 8.81 Qes = 0.86 Qts = 0.79 Vas (Liters) = 156.75 Cms (pM/N) = 150.65 Mms (Grams) = 299.00 Sd (sqMtr) = 0.0856 BL (T-M) = 15.27 No (%) = 0.23 SPLo (dB) = 85.71 My C15 is not broken in yet but the difference is not much. About 10%. Vas will be slightly larger, Fo slightly lower. You are right, it is suitable for IB. With a Sealed Box volume of 35cu ft (1000L), the Q=0.85 I haven't got the time to box the C15 so I can't tell you how it performs. The T/S is only good for assisting in the box loading/tuning. Regardless of how well you load the driver, some subs simply has no definition. These are the ones that are "boomy". The ones I'm after are those that have punch and good definition. When its right, you can make out a lot of information in the bass. The only way is to listen to them. Rob is absolutely right. Simulations are very accurate. The problem lies in the accuracy of the T/S data. If one does a lot of speakers, it is a good investment to get one of those woofer tester from Parts Express. Mike
AmpsLab.com |
| Simulations in Pass Article | Michael Rothacher | Pass Labs | 2 | 26th March 2008 10:49 PM |
| Seas L15 simulations | Khron | Multi-Way | 3 | 11th April 2006 04:38 AM |
| Assistance with SPICE Simulations | JMB | Multi-Way | 2 | 8th February 2006 09:28 PM |
| Xamp-simulations problem_s | grataku | Pass Labs | 25 | 31st July 2003 05:10 PM |
| Protel simulations | Kees | Solid State | 2 | 12th November 2002 03:47 AM |
| Page generated in 0.06930 seconds (78.22% PHP - 21.78% MySQL) with 11 queries |
