Help me fix my MTX 1000D, no sound, just static
Bought this MTX 1000D monoblock from ebay broken. The amp powers on but there is no sound just static noise goes to speakers.
I checked all FETs they are all good, as well nothing looks burned on the board exept one diode that I checked and it is still good the D446 (MUR1540).
But looks like someone was fixing it, installed the capacitor 220uf on the U141 (THAT 2155) and also 50ohm resistor under it.
Does anybody know where I should start?
Does LED238 light up?
Do you have a scope?
If that amp uses SSP45N20As in the audio section, clamp the power transistors down and never apply power without having them clamped down. If the output transistors fail, the amp may be VERY difficult to repair. These amps are VERY sensitive to changes and it's VERY difficult to find replacement FETs. Even if you find some NOS SSP45N20As, they may not work.
LED does lite up. I don't have a scope. I just was testing it further, all FETs are clamped down, but buzzing noise was there, no sound, then all of a sudden all FETs from 436 to 441 labeled 75339P blew up, lit on fire! One of the ssp45N20a blew up too
Whats going on here
The power supply FETs failed. Did the output FETs fail also (do any read near 0 ohms from leg 2-3)?
Whenever working on an amplifier, you should always have a relatively small (~10-15 amp) fuse in the B+ line. It helps protect the amp from significant damage (generally).
good idea with the fuse thing, next time I will use it. Yes two output ssp45N20a blew up too, as well as all power FETs. Subwoofer blew too, this may be the cause.
But why did I have static noise before things blew up?
These amps can be very difficult to repair when the outputs have to be replaced. Even when I have one on the bench, it can be very time consuming to repair. At one time, I considered making a clocked drive circuit board for them to make them easier to repair but I don't see enough of them to make it worth the time.
It's nothing personal. These amps can be very difficult to repair when the outputs need to be replaced. The other amps were easy to repair.
I learned the hard way that these aren't generally worth the time. I've tried exact replacements (NOS) as well as other FETs and generally had lots of problems. In the same amps, I tried a set of old, used outputs that were from another amp and the amps worked fine. I went back to the replacement/substitute outputs (including exact replacements) and the amps would not work properly.
I got this amp for $40 so it is not a big deal then, I will just use it for spare parts.
Sense you know a lot about gutz of the amps, what brand of amps are good right now? Sense most of them are junk china made these days, what models of amps do you recomend me to buy as new for bass?
I've always been a fan of Rockford amps. Sure, they made a few turkeys but for the most part, they've made good quality amplifiers that are good for 20+ years if used as they were designed to be used (no 2 ohm mono on an amp rated only for 4 ohms mono). The new stuff is still pretty good and you can generally buy them for just a bit more than the cheap amps.
Thanks a lot man. These MTX amps all have parasitic load of .050 amp when connected power remote off, that is high enough to drain the car battery if left for a week without driving. How are Rockford amps with this?
