Go Back   Home > Forums > General Interest > Car Audio
Old 27th October 2009, 10:49 AM   #1
ZippyTs is offline ZippyTs  United States
ZippyTs's Avatar
Question Need a Manual
Well I am a new member here, and was inspired by the old school debate thread to get a nice older amp. Maybe not as old or nice as some of the wonderful amps Tomtomjr or tsmith and others have, but so far after bench testing it seems nice. It was a joy to read the full 73 pages of the thread, and can not wait for more to come along. Well with that out of the way the reason i made this thread is I am now looking for a manual for my new/old school amp
it is a Audio Art 260.6xe. When i was testing i was running into amp input, and bypassing the crossover. What i really want to do though is use the crossover and run the amp in 4 channel to run my front full pass (direct to amp input) and my rears in bandpass for mid range fill. I just want to make sure I do it right, and not mess up the amp in the process.
Thank you all in advance
Zippy
Old 27th October 2009, 01:56 PM   #2
tsmith1315's Avatar
Nice amp, post a picture! (Help me re-live my youth)
I doubt I have a manual or diagram, but will look around this afternoon for info. Is the internal crossover a 3-way? I doubt you'll be able to bandpass without an additional filter. But as long as the front speakers are wired correctly for bridged mode and you have good power/ground, there's not much chance for damaging the amp.
BTW, my collection is small and insignificant comapred to many others here...
Tim
Old 27th October 2009, 07:52 PM   #3
ZippyTs's Avatar
I will try to get some picks up here in a bit. It is a 3way internal crossover that's is separate from the main board.
Old 28th October 2009, 08:25 AM   #4
ZippyTs's Avatar
Couldnt find how to edit my last post to prevent double post so here they are in all there glory
Click the image to open in full size. overall
Click the image to open in full size. board model number
Click the image to open in full size. power side
Click the image to open in full size. sub crossover
Click the image to open in full size. preamp side
Click the image to open in full size. and insides
Old 28th October 2009, 10:44 PM   #5
tsmith1315's Avatar
Cool. The way it's set up gives you maximum versatility, just like the old HiFonics amps.
I don't get the sub crossover on the side can you post a larger pic of that, or is it that just the bass EQ adjustments?
With the switch in "2-way +sub" it most likely sums the input to the low frequency filter and bypasses the bandpass for highpass only on the other outputs.
For the full-range bridged channels, just use a pair of Y-adapters to tie the inputs of the A channels together and B channels together (or B and C). Power output is equal on all channels, right? Then, use the ungrounded leads from A channel as one pair of the bridged speaker leads, and likewise for the B channels. These are easy to find if you don't know how.
edit: On the "board model #" pic, do you know what the switch is for?
For the bandpass channels, switch the crossover to 3-way mode, and run your signal into either front or rear inputs on the crossover. Connect the crossover's mid output to the other unused pair of amplifier inputs.
Tim
Old 28th October 2009, 11:25 PM   #6
ZippyTs's Avatar
Well it is a
4 x 35 wrms + 2 x 60 @ 4 ohms
4 x 70 wrms + 2 x 120 @ 2 ohms
2 x 140 wrms + 1 x 240 @ 4 ohms bridged
Photobucket album
I was hoping you could tell me what the switches are for lol. I included the photo album so you can see the bigger pictures and also a new pic of the bottom. Yes the side view is a bass eq, and not a crossover to early in the morning.
As for the abc channel would AB be the 4x35, and the C be 2x60
What i want is to bridge AB for the 140w to run fronts, and C to run rears.
thakns in advance
Zippy
Old 28th October 2009, 11:56 PM   #7
tsmith1315's Avatar
Are there 3 switches?
Looks like it, and I would expect them to invert channels for bridged operation.
All speaker negatives are black and run to a common point?
edit: OK, I just looked again and saw the pic of the bottom cover. They must be for switching to bridged mode. On=bridged, off=stereo. They just invert polarity on one channel.
Tim
Old 29th October 2009, 04:09 AM   #8
ZippyTs's Avatar
how will i know for sure? will i damage the amp if they are set wrong?
Old 29th October 2009, 05:27 AM   #9
tsmith1315's Avatar
The speaker wires would be the clue...
Since your amp has a bridged power rating, it is obviously bridgeable.
- Some bridgeable amps have one channel (per pair) already inverted by design. To bridge these amps, you simply use the two wires that are "hot" with respect to power supply ground. Since the polarity is inverted on one channel, the "hot" wire will actually be a negative speaker output. So, in stereo operation, these "hot" wires will be a positive from one channel and a negative from the other channel. No switches are necessary.
- The other bridgeable amps have switches to invert the signal before it is amplified. Too bridge these amps, you use the two (+) wires from the channels being bridged.
- An amp that doesn't have either of these features isn't bridgeable without external components.
So... it appears that the black (negative) speaker wires in your photo are connected to the same point. That would indicate that the (+) wires are "hot" and it would require the switch to invert phase on one side, so that (+) output could be used as a (-) output.
Unless, of course, the wire colors were confused when they were replaced.
You can verify the connection visually, or with a DMM set to measure resistance or continuity. If half of the speaker (+) outputs are connected to the other channels' (-) outputs, the switches aren't for bridging.
A few amps have internal switches for low-impedance operation, but the switches would be labeled as 4ohm-2-ohm, not on-off.
That was a long repsonse to simply say:
Other than in the low-impedance case, an incorrect switch position wouldn't damage the amp. But it wouldn't sound too good.
Tim
Old 29th October 2009, 06:24 AM   #10
ZippyTs's Avatar
ok i think i got what ur saying now. so if channels a and b are the 4x35 and i want to bridge them do i set both A and B switch to on, or just one. how will i tell once bridged what is positive and neg for the 2 positives. lastly do i need to hook up both left and right inputs for channels A and B for the bridge?
Thanks once again
Fellow Smith
Seek help: Leader LDM-171 user manual (Service Manual) 0451ym Parts 0 28th June 2008 05:18 PM
DBX 1BX-DS Manual John Irvine Parts 0 2nd June 2008 07:46 PM
Manual for old ADS amp variable Car Audio 0 25th June 2007 06:30 AM
So, where's the manual? :) Socrates428 Chip Amps 1 20th March 2007 09:14 AM
Old TEF Manual bzdang Multi-Way 0 10th March 2005 05:46 AM
Page generated in 0.12359 seconds (78.99% PHP - 21.01% MySQL) with 10 queries
