Go Back   Home > Forums > General Interest > Car Audio
Old 25th October 2009, 03:27 PM   #1
luka is offline luka  Slovenia
luka's Avatar
Send a message via Skype™ to luka
Default Terminal block for car audio
So I needed some kind of connector that will be part of car amplifier, and could handle few 100A if scaled up a bit, my will probably never see 100A, even peak.
What you need is:
- Some plastic cap, probably used to cover holes, like at the ends of metal tubes or something
- Long nut that will fit inside plastic cover and still have space around it
- Hot glue
- And screws the same size as nuts
First you make small hole with drill into center of the plastic, say 2mm for start and for drill guide. Next you make hole big enough so that screw can be screwed in. From other side you put on long nut, which is good if taller then plastic edge.
Use washers on both sides of the plastic to spread the force, if you will need to make really good connection for high currents
So now you have solid connector, but nut inside is held by output, removable screw, so we need to glue it. I used hot glue(epoxy would be great too), really strong stuff, I didn't think it will be so much. I used it,because I filled plastic and it got cold to fast, but if you heat nut (that is why longer nut), I could keep glue hot enough, so that it came in all corners and griped nut really good. Then just let it cool down, maybe help it a bit with ice. And that's it, one solid connector done.
I used for 12v path M10 set of screws and nuts, for output I kinga over done it and used M8
3 terminal regulator with 3 terminal shunt reference BWRX Power Supplies 11 17th January 2013 09:08 AM
Car amplifier terminal block darw82 Vendor's Bazaar 1 29th June 2010 09:33 AM
USAMPS USA 100 Terminal Block Mounts chemhaz Car Audio 1 26th February 2009 05:03 AM
source for xtant 2200 terminal block natedogg220 Car Audio 2 18th June 2008 08:03 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
