#21 |
Clamp everything to the heatsink and insert a 10-15 amp fuse in the B+ line before applying power.
If I'm not mistaken, there are two screws in the board that had lockwashers. One is near the B+/ground terminal block. The other is near the small daughterboard. Reinstall both of them with their washers.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#22 |
No, No lockwashers that I see. It has clips in the center that don't even let the screws bottom out. I am just noticing something, I have my transistors here and two of the IRF 9640 are marked IRF 640. I am sure this passed me over seeing the 640 termination and I bought and installed all IRF 9640. Is this an error on my part or is this an error on kicker. If it is my error in which positions should it use the IRF 640?
Next area, No power up as of yet. The center leg on the 3205 has B+ but no signal on the other two pins. |
#23 |
If it has 6 outputs for the class D section, 4 are likely 9640s and the other two 640s. The 3rd leg of all of the 9640s will be directly connected (0 ohms) and the 3rd leg of the 640s will be directly connected.
#24 |
ok, got that taken care of..... what you think, throw it in the trash or is it fixable
#25 |
Unless the board is burned beyond repair, it's repairable.
#26 |
the board itself looks good. But no rail voltages yet. Everything is replaced. what do you want me to check next?
#27 |
Did you power it up?
#28 |
yes i did. Same as before. Still have 7v on the rcas and 7v on the speaker output and on the kd718 I only get 7v too.
#29 |
If you insert a 10 amp fuse in the B+ line, does it blow the fuse when you power it up (including remote)?
#30 |
No sir, doesn't even blow a 7.5 amp fuse.
| Blown amp pre-amp in or HU pre-amp out? | scraph | Car Audio | 5 | 23rd January 2009 01:58 AM |
| Sub or Amp Blown | kdhorne73 | Car Audio | 6 | 21st January 2009 02:32 PM |
| mtx blown please help | ADRIANd | Car Audio | 32 | 1st October 2006 12:35 AM |
| PPI 600.4 amp blown?? HELP!! | D_Bull | Car Audio | 1 | 4th March 2005 06:18 PM |
| Blown AMp?? | zorb_rules | Car Audio | 0 | 25th June 2004 09:39 AM |
| Page generated in 0.09476 seconds (76.79% PHP - 23.21% MySQL) with 11 queries |
