Go Back   Home > Forums > General Interest > Car Audio
Old 4th December 2009, 03:10 PM   #101
You'd want to confirm that the meter reads OL base to emitter and base to collector with the probes placed one way and several megaohms with the probes reversed. It should read OL no matter the placement on the collector and emitter.
If you're still unsure about the test procedure, go to the following page. Find the section shown in the attached image, read what's circled and follow the instructions. In this instance, it would be better to set your meter to ohms instead of diode-check because the transistors may only be leaking.
Basic Amplifier Repair - Transistor Test Applet Link
Old 4th December 2009, 03:20 PM   #102
both of them are bad, they both have continuity between emitter collector and one doesn't show mega ohms like it should between emitter, base.
Old 4th December 2009, 03:25 PM   #103
OK, well let us know if there are any other problems after replacing them.
Old 4th December 2009, 03:34 PM   #104
will do, one last question. Do you think both of these are the same part numbers. the q315 has a hole burned in it on the top. Can only see it with a magnifying glass
Old 4th December 2009, 03:41 PM   #105
They should be the same.
Old 5th December 2009, 01:57 PM   #106
got both of them replaced and the amp was put to work yesterday at idle for about 5 hours and so far so good. Today will hook it up and try it out..
Old 7th December 2009, 03:03 PM   #107
Perry, Ran this amp all weekend in my car and everything is a ok..... Thank you again. You know ur stuff...
Blown amp pre-amp in or HU pre-amp out? scraph Car Audio 5 23rd January 2009 01:58 AM
Sub or Amp Blown kdhorne73 Car Audio 6 21st January 2009 02:32 PM
mtx blown please help ADRIANd Car Audio 32 1st October 2006 12:35 AM
PPI 600.4 amp blown?? HELP!! D_Bull Car Audio 1 4th March 2005 06:18 PM
Blown AMp?? zorb_rules Car Audio 0 25th June 2004 09:39 AM
Page generated in 0.07669 seconds (82.61% PHP - 17.39% MySQL) with 11 queries
