Car Audio PSU Ideas
Car Audio PSU Ideas
Old 15th June 2003, 02:53 PM   #61
N-Channel is offline N-Channel  United States
N-Channel's Avatar
Send a message via AIM to N-Channel
Yup! Hope this helps with your PSU.
Old 16th June 2003, 04:17 AM   #62
dkemppai is offline dkemppai  United States
Default Re: 2.5 in. Toroids!
Originally posted by N-Channel
2.5" o.d. Cores??? WOW!
Check out magnetics TC47313 cores... ...2.75 inch dia!
-Dan
-With a bad amp, everything sounds the same. It takes a good amp to tell the difference between true "Artists" and the rest of the "Performers".
Old 16th June 2003, 08:37 AM   #63
fr0st is offline fr0st
I just found the magnetics site then and it seems they've got an Australian distributer
The 48613 is 3.375inchs ! I've sent an e-mail to them to see if they've got any of the 2.4inch and greater cores.
I might be able to pull this project off with a single core yet
Old 17th June 2003, 08:49 AM   #64
I got in contact with the AUS reseller and they've got some of the 3.375 inchers
I'm so happy lol
I know it'll probly meet my power requirements but how much would a core like this put out?
Old 17th June 2003, 12:45 PM   #65
I'm so happy lol
Not exactly sure, but I'm guessing well over 10kW... .
I'm guessing that the size of the core may make it difficult to use.
What material type are you looking at? I've used the P type. Any ferrite should be good. Look at core losses vs operating frequency for the frequency you'd like to use.
-Dan
Old 18th June 2003, 06:04 AM   #66
The company has the P and J (I think) type. P has no coat and the J is coated but has a permability of 5500u. The P is about 2500u so I'm going to order that since n channel used near that before.
Old 18th June 2003, 08:40 PM   #67
N-Channel's Avatar
Talking 2500u
Yep. The cores from Amidon worked great. I finally figured out how to get the power supply pics under 100k in order to post. When I get home tonight, I will post them.
Old 19th June 2003, 01:42 AM   #68
The p type has some nice characteristics. It actually increases efficiency until you get the temp over 120C. I've never even actually been able to heat one up that hot!
-Dan
Car Audio PSU IdeasHide this!Advertise here!
Audio [Radio] Amplifier Ideas Needed audiohobby Solid State 0 27th February 2009 01:21 PM
Any ideas on how old this is? awhite1159 Tubes / Valves 5 16th September 2007 04:32 PM
Hidden audio goodies (ideas for an odd driver pairing) copper Multi-Way 4 31st August 2005 03:48 AM
Homegrown Audio interconnect ideas. vincentrubble Everything Else 0 17th December 2004 05:55 PM
