Go Back   Home > Forums > General Interest > Car Audio
Old 17th October 2009, 04:22 PM   #1
Bertje is offline Bertje  Netherlands
Default JL Audio 500/1 repair info
Hello,
I have here a JL Audio 500/1 d class monoblock. Power supply failed, I changed all mosfets (FPQ65N06) and gate-resistors (47 ohm).
Worked, but has very low railvoltage, maximum undistorted output is 15w, then it clips.
I think the drivers of the mosfets from the PS are also faulty, I measure a pulses of about 5v and 1,7uS from the SG3525 (OK) but after the drivers they are distorted.
Drivers are UY 142 and WY 143
I looked at smd coding tabels etc. but can't find them....which type I can use here??
Thanks,
Rob.
Old 17th October 2009, 09:18 PM   #2
jl 500/1 SMD transistors
Old 17th October 2009, 10:17 PM   #3
Thanks a lot! Sorry for not searching.....
Rob.
Old 27th October 2009, 09:14 PM   #4
OK, power supply is OK now, up to 150v dc at the rectifier out without a load.
Is this a regulated supply?
Rob.
Old 27th October 2009, 09:32 PM   #5
You shouldn't have more than ~80v at the rectifier.
Yes, it's regulated.
Old 28th October 2009, 09:30 AM   #6
OK thanks. I measure 150v DC with the rectifier disconnected from the rest of the PS. Just AC input, no load.
So I think something's wrong with the feedback of the regulation. Also a resistor was burnt 6k2 (R661) which I changed for 6k8, difficult to see what this resistor do without schematic. Could be in the PS regulation loop, not sure.
Rob.
Old 28th October 2009, 09:49 AM   #7
What is the voltage on the first two pins of the driver board (looking at the component side of the driver board)?
I think you'll have to have the rectifier installed but I'm not sure.
Are you 100% sure that you read 160v DC on the center leg of the rectifier? It should have caused the filter caps to vent at 2x their rated voltage.
Old 28th October 2009, 11:06 AM   #8
I connected only the outside legs of the rectifier to the board. The center leg is not connected, floating. Then I measure 150V dc. No regulation offcourse.
With the rectifier connected (normal regulation) the output is about 40Vdc.
Or the PS regulation is defect, or the amplifier is..
But with signal on, I have normal amplifier output to 15w, then it's clipping.
So I suspect the regulation of the powersupply.
Strange problem...
Rob.
Old 28th October 2009, 05:59 PM   #9
Old 28th October 2009, 07:56 PM   #10
I got your cd and info, so when I looked at the pinvoltages:
1 = 9,2V feedback ? (
2 = 2,5V Ref
and the rest are OK.
The resistor in front of the feedback was burnt and is exchanged for 6k8 (was 6k2). This resistor is connected directly to pin 1.
Close...
Rob.
Swiss Physics 6A repair info Cole Johnson Solid State 2 5th October 2010 08:42 PM
Repair scatches on Plexigalss or lexan - Info HeavyD'sCustom Car Audio 8 15th May 2009 06:41 PM
Teac LS500 speaker repair - info needed Brisso57 Multi-Way 1 6th September 2008 12:52 AM
Nak ST-7 circuits or repair info please MadMutt Analogue Source 14 3rd September 2007 02:10 AM
Sony dat REPAIR INFO superdave058 Digital Source 3 5th May 2007 08:52 AM
Page generated in 0.11053 seconds (76.84% PHP - 23.16% MySQL) with 10 queries
