earthing rca shields... - Page 3 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 16th October 2009, 06:35 PM   #21
Did you confirm that the signal source shield ground had ~0 ohm continuity to the ground terminal of the amp (with the shield to sink jumper removed)?
Old 16th October 2009, 06:42 PM   #22
marko is offline marko  United Kingdom
but it would if it was disconnected surely?
Old 16th October 2009, 08:35 PM   #23
Old 17th October 2009, 02:50 AM   #24
TO-3 is offline TO-3  Peru
TO-3's Avatar
Send a message via Yahoo to TO-3
Originally Posted by marko View Post
i've been working from the rca's back to the board, maybe i should work from the other end and see what happens!
where the signal connects to the main board should i have resistance there to the negative terminal like i should at the rca shield?
i will get this sorted this weekend!!!
Wait, from the signal, or the ground? There should be a high resistance on the signal pin to the negative terminal. Now, from the RCA shield to the negative terminal, there should only be up to a couple hundred ohms.
Check out Tube Driver BLUE products at: www.tubedriver.com
Old 18th October 2009, 05:46 PM   #25
there is continuity at the main board black wires to DB to negative terminal.
but not rca shield to negative terminal.. nothing there at all!
the source cd player is ran off it's own little power supply if that helps?
Old 18th October 2009, 06:06 PM   #26
Connect the ground terminal of the head unit's power supply to the ground terminal of the amp's power supply.
Then confirm that the head unit shield ground has ~0 ohm continuity to the ground terminal of the amp (with the shield to sink jumper removed)?
Old 18th October 2009, 06:28 PM   #27
ok, my findings are as follows, with a wire connecting both headunit earth and amp earth up together the amp works correctly..
from rca shield to neg terminal with both jumper wires connected or disconnected (just leaving power connected for DB) i get very high readings on the mm set to resistance..
Old 18th October 2009, 06:38 PM   #28
Check the shield ground as described on the following page:
RCA Shield Repair
Old 18th October 2009, 06:51 PM   #29
checked headunit as above and that's fine.
Old 18th October 2009, 08:07 PM   #30
When you said "from rca shield to neg terminal ....", I assumed that you were talking about the head unit and not the amp.
So... if the amp works properly, the problem was the lack of continuity between grounds of the two power supplies.
transformers with electrostatic shields rick57 Parts 16 27th March 2013 09:37 PM
MTX 202 power on shields jol50 Car Audio 4 1st November 2008 08:21 AM
Tube Shields korneluk Tubes / Valves 1 17th December 2007 04:31 PM
Magnetic shields for transformers dsavitsk Tubes / Valves 12 21st October 2007 11:51 PM
Electrostatic Shields Gumboots Tubes / Valves 5 21st August 2002 02:48 AM
Copyright 1999-2017 diyAudio
