will Being Mr cheap work this time? - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 9th October 2009, 12:10 AM   #11
A circuit breaker is as bad if not worse than the fuse.
If it ain't broke Don't fix it
Old 9th October 2009, 12:25 AM   #12
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Originally Posted by Glowbug View Post
The best thing to do would get the proper size cable for your current draw
Techflex. But leave the 16awg for other uses...
agree x 100% do it right the first time, in anyevent, cutting corners just causes 100000x more pain later down road
WIRE is not that expencive, just buy a kit,
Old 9th October 2009, 12:40 AM   #13
Glowbug is offline Glowbug  United States
Glowbug's Avatar
I don't know about suppliers over there, but Knukonceptz is recommended a lot here for a mid-priced wiring kit: http://www.knukonceptz.com/productDe...prodID=KLM-AK0
I've used their wire before, it's not the best but it'll do the job safely and securely.
The best I've used is the Kicker Hyperflex kit, but it's about twice the price Worth it if you ask me, though...something that can burn your vehicle to the ground if done improperly isn't the place to skimp, IMO.
Jim
The machine does not isolate us from the great problems of nature but plunges us more deeply into them. - Antoine de Saint-Exupéry
Old 9th October 2009, 02:33 AM   #14
jol50 is offline jol50  United States
Unless you can find some welding cable.
Old 9th October 2009, 03:13 AM   #15
Banned
http://www.woofersetc.com/c2/Amp-Kits.htm
Good company also.!
Old 9th October 2009, 09:34 PM   #16
sdoom is offline sdoom  Germany
How much current are you going to pull over that "cable" ? A 16AWG (if am right that would be 1,5mm² in those "metric system" countries --> hey thats where they call a quarter pounder a "royal cheese"....) Will aprox. withstand 50-100 amps for a few seconds. So i agree with the already posted opinions. to make sure your car does not go up in smoke you should use more smaller fuses for at least a couple of those small wires. the "main" fuse placed next to the battery is not supposed to protect your amplifiers, it´s supposed to protect the battery and the wires in case of a short. the problem is , that a 40A fuse will not blow while 40A current are flowing over it. The fuses will withstand much more current until they blow, now keeping that in mind you need to consider which goes first, the fuse ore the wire !
Either make sure the wires cannot fail (that means spending money on a very good isolation material/ hose) or use smaller but suffiicent fuses. You would have probably been better of with using 3x 10mm² and a 100A fuse or a 140A curcuit breaker.
Cheap first time subwoofer help loctus Subwoofers 2 22nd September 2009 02:30 AM
cheap time delay relay for soft start? mpmarino Parts 0 20th January 2007 09:47 PM
Cheap headworn magnifier forSMD work. alcar Class D 3 14th July 2005 01:49 PM
cheap speakers for computer at work cowanrg Full Range 7 4th June 2004 08:38 AM
First time designing a sub, please check my work mFinalHeaven Subwoofers 37 19th August 2003 12:14 AM
Copyright ©1999-2017 diyAudio
