MTX 421D issues
MTX 421D issues
Old 22nd September 2009, 07:27 PM   #11
brandes.cm is offline brandes.cm  United States
My Vgs is high then, surprising the fet has held up.
I sent you a pm.
Old 22nd September 2009, 07:31 PM   #12
Perry Babin is offline Perry Babin  United States
The Vgs probably isn't high. When the gate is 10v above the rail, the source is at the rail so the Vgs is only 10v.
I sent the service manual.
Old 22nd September 2009, 07:49 PM   #13
Thanks, got it. This should help.
Old 22nd September 2009, 09:06 PM   #14
So I have what seems to be nice square wave osc. on the source of FET101 and the drain of FET191. Measure about 80Vpk-pk roughly 64Khz.
I get very little amplitude when running a 1Khz sine into the inputs. I can vary the amplitude without any change in the output. Should I be looking at the LM339?
Old 22nd September 2009, 10:06 PM   #15
Not much of the 1k sine wave is going to make it through the crossover. Go to a 60hz sine wave.
Old 22nd September 2009, 10:57 PM   #16
17DoubleE is offline 17DoubleE  United States
Default Good point on the 1KHz not making it through the cross over.
The guy that suggested a 1KHz test signal probably forgot this is a sub
amp!
Old 23rd September 2009, 12:50 AM   #17
That is funny, never even thought about it being a sub amp!
Old 23rd September 2009, 11:48 AM   #18
Thanks Perry for the help, the amp is functioning. I only have one set of output fets in place right now but that is enough to hear some sound from it.
Amazing what happens when the correct freq gets through!!
So to sum up the issue: Bought from ebay known bad, output caps burst, one fet shorted and the NE5532 that gets feedback or feeds signal to output was damaged. It also had a couple SM resistors burned in that circuit.
That is 3 amps repaired this week, 1 punch 60DSM, 1 Pioneer GM-X502, 1 MTX 421D.
Thanks,
Cory
Old 27th September 2009, 06:57 PM   #19
Solosound is offline Solosound  Mexico
Solosound's Avatar
Dear Brandes.cm:
I suggest to you acquire the Perrys tutorial repair amp.
“The information provided in this tutorial will help you to avoid making the most common mistakes and will greatly increase your chances of success”
http://www.bcae1.com/repairtutorialcdinfo.htm
MTX 421D issuesHide this!Advertise here!
NAD 216 issues Kamuy Solid State 28 17th December 2009 03:16 PM
Looking for MTX 421D info brandes.cm Class D 1 23rd September 2009 04:20 PM
MTX Thunder 421D spooney Car Audio 5 19th April 2008 03:40 AM
MTX Thunder 421D.Plays fine at times but occasionally blows a fuse?Input appreciated spooney Car Audio 2 13th June 2007 10:59 AM
mtx 421d amp catchuk Car Audio 1 5th February 2004 10:20 PM
