My front mains are peaky above 1kHz and the crossover only has an inductor. I think I can improve things by adding a zobel network across the woofer out terminals of the crossover but I need a formula I can use. I don't want to measure the impedance, I'd rater do trial and error but I need the formula to put me in the right starting place.
#2 |
how big is your inductor
what kind of woofer what kind of tweeter are there no cap on tweeter |
#3 |
A Zobel reduces the rising impedance of the woofer...you need to have the DC resistance (measure with a meter) and the Le (electrical inductive equivalent of the driver)( from the T/S specs.
Then it's: Rz = Re x 1.25 Cz = Le / Rz^2 Where Rz is the zobel R, Cz is the zobel C. |
#4 |
how big is your inductor....don't know. By looking I'd guess no bigger than 150mH
what kind of woofer....6 inch kevlar cone what kind of tweeter....1 inch silk dome. Rolls off below 2k. are there no cap on tweeter....4.5uF and small value adjustable resistor. Oh, and there is no available value for Le. |
#5 |
#6 |
![]() To be honest, I'm not even sure whether the full zobel would be a good thing. The crossover was obviously designed to be an improvement on the raw drivers and if I go full zobel I'll also have to re-do the inductor, then I'll need to re-do the tweeter. I'd rather buy better speakers. I do appreciate your help. I measured re as 3.8 ohms so I'll try a 4.7 ohm resistor. |
| Zobel Or No Zobel ? | sakis | Solid State | 74 | 2nd March 2012 09:32 AM |
| which cap do you like in zobel ? | sandro600 | Solid State | 2 | 28th January 2007 10:36 AM |
| zobel | Streets97f | Subwoofers | 4 | 19th November 2006 04:44 AM |
| I'm sorry, but the amp needs a zobel | carlosfm | Chip Amps | 82 | 26th December 2004 04:59 PM |
| Page generated in 0.08209 seconds (75.49% PHP - 24.51% MySQL) with 10 queries |
