Using a high Q filter to fill a dip - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 17th September 2009, 11:33 AM   #11
AllenB is online now AllenB  Australia
Originally Posted by richie00boy View Post
Hmm thats a very bad way to mount the drivers, they need at the very least a baffle to prevent front to rear cancellation.
The original drivers were mounted this way. If anything, they sound more solidly mounted than if they were on the trims.
One thing though, the original speakers had open cell foam stuck around the outside of the roll surround, reaching forward to the trim. Maybe I should try this.
This could be your problem but equally standing wave nulls at the measurement position could be too.
I haven't been able to re-measure yet but if this is the case, will I just have to live with EQing for my location at the expense of complexity and other seats sounding out of balance?
This problem also goes for my sub/woofer. I wish it didn't sound so much louder in the back.
EDIT: Maybe I should stuff my doors, they could be causing not only cancellation but peaks in the upper midrange?
Old 19th September 2009, 03:54 AM   #12
I did those things (except I used soft but very dense foam) and I remeasured the response.
The response is flat and normal around 400Hz both nearfield and at 30cm but it is not level at my listening position as you guessed.
Would I be best doing anything about it?
Old 19th September 2009, 10:38 AM   #13
Did it Himself
richie00boy's Avatar
Up to you really, first question to answer is do you find the sound ok?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 19th September 2009, 12:53 PM   #14
OK, that's great.
I've been working on smoothing the upper midrange and the sound seems to be coming together. The problem in the lower midrange is less of a concern and I've been able to get back to listening. I adjusted my crossover to ease the lower mids back up a little. Just a few more tweaks, I think...
high pass filter (crossover) derekyu Multi-Way 8 30th March 2007 06:32 PM
high gain 2nd order high pass active filter topology sreten Solid State 21 23rd March 2006 02:26 AM
high-pass filter (low-level) keyser Parts 3 6th December 2004 04:02 PM
Low/High Pass Filter fatpower17 Car Audio 1 28th June 2004 09:45 AM
high pass filter for jx92, j-low? jfk Multi-Way 0 16th October 2003 08:32 PM
Copyright 1999-2017 diyAudio
