I know these questions are asked alot everywhere, but I'm still unsure of my systems requirements. Need a little guidance, folks.
'01 Silverado 4.8L , stock alt. 105a (I believe, not sure how to check) Alpine CDA-105 H/U Alpine MRP-F300 4 channel > Infinity components 6030cs front/4x6 plates rear Clarion DXP2251 2 channel > Infinity 1052w subs 10" x 2 down firing box The Alpine amp is rated 300w max rms w/ 2 x 25a fuses; 50wx4 @4ohm, 75w@2ohm . The Infinity's components are rated 2 ohm stable but I read they are 2.9 ohm. This confuses me somewhat. The Clarion is a class GH amp, rated 600w x1 (bridged) rms, 2 x 40a fuses. The Infinity subs are 10" DVC, rated 250w @4ohm. All ratings are CEA . Using this chart, I can use 4 awg from the batt to a DB , then split with 4 + 8 to the amps. The total amp draw would be 130a. Other references say I need more of everything. I plan on doing a "big 3 upgrade' since my GM side mounts on the battery need adapters anyways. But, it looks like I may need to consider an alternator upgrade as well. Considering I'm an older guy and I don't listen to my music at full volume I'm guessing I wont be using that much current draw. I'm not really sure how that factors in, but I'm thinking it does. Any comments are welcomed. |
#2 |
I'd split two 4 gauge at the battery right into the fuse holder and run one to each amp. You can use one 100-150 amp wafer fuse and save using a splitter.
Don't worry... you can always turn the gain down! |
#3 |
Go to www.bcae1.com and click on wire (#17) on the right side. All will be explained.
| Help with BTL power requirements | dayveshome | Solid State | 5 | 28th March 2008 11:45 AM |
| TPA6120 Power Requirements | dfdye | Chip Amps | 8 | 19th February 2007 08:30 AM |
| LM4780 Power Requirements | otherside | Chip Amps | 12 | 12th July 2006 05:07 PM |
| Power requirements for biamping | Circlotron | Multi-Way | 10 | 30th October 2002 04:00 PM |
| Biamping power requirements | woody | Multi-Way | 3 | 3rd January 2002 01:34 AM |
| Page generated in 0.06600 seconds (70.16% PHP - 29.84% MySQL) with 10 queries |
