![]() ![]() The larger 10 ohm resistor (in the middle of the zoomed picture), burns and causes that channel to distort. I replace the resistor, and the amp works again for a week, then it burns again?? I have found no other damaged parts (output transistors, diodes or other resistors). Why would this continue to overheat? What is the function of this resistor? Source resistor? The amp has a 2.6 ohm stereo load on it. Thank you in advance for any insight. Mark |
#2 |
Your picture does not show up. Is it a 2 watt resistor? Is one leg of the resistor connected directly to one of the output transistors? Is there one resistor per output transistor? If you answered yes to all 3 questions, chances are the resistor is a (.)1 ohm resistor.
If it ain't broke Don't fix it |
#3 |
#4 |
#5 |
#6 |
What is the DC voltage on the following resistors (no audio, measured directly across the resistor terminals)?
R148: R149: R151: R248: R249: R251:
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#7 | |
r149: 1.173v r151: .004v r248: 1.31v r249: 1.43v r251: .004v r151 and r251 are the resistors that are burning, and causing distortion. The others listed still read 300 ohms. There has been 2 cases where r177 also burned. Replacing these resistors fixes the problem, but I have had to do this repair several times. r151 appears to be a 10 ohm 1% 1 watt resistor, would increasing it to a 2 watt resistor help? Maybe I am just pushing it to hard or maybe I have not found the additional faulty components. Thanks for the help. Mark |
#8 |
There's nothing there to indicate that there is a problem.
If you're driving it into hard clipping or if you're running it below 2 ohm stereo/4 ohm mono, that could be the reason that the 10 ohm resistors are overheating.
#9 |
It is running at 2.66 ohms. Maybe I will rewire to a higher impedence. Thanks for the help, I am probably just driving it to hard then. I will have to do some gain adjustments and rewiring and see what happens.
Thanks again, Mark |
#10 |
I am repairing my 451s Amplifier. I notice that Diode D7 is burnt and cracked open. The D7 is in the vicinity of R215 and R32. I can't find the part number anywhere. Can someone please advise me so I can order accordingly.
Thanks, Matt |
| Rockford Fosgate P800.2 [Repair] | woutzor | Car Audio | 94 | 29th May 2010 04:30 AM |
| Repair of Rockford Fosgate Punch 201s | Jackson75 | Car Audio | 15 | 3rd November 2009 10:34 PM |
| Rockford Fosgate Power 800.4 | lostamps | Car Audio | 6 | 2nd January 2008 12:21 PM |
| Rockford Fosgate punch/power 500.2 | Clipped | Car Audio | 2 | 11th July 2007 07:08 AM |
| Page generated in 0.10754 seconds (78.82% PHP - 21.18% MySQL) with 10 queries |
