Go Back   Home > Forums > General Interest > Car Audio
Old 31st August 2009, 06:28 PM   #1
Default Lanzar vibe 266
my son bought off craigslist speakers and the amp, hooked everything up worked great, then when turned back on had blown radio fuse, replaced fuse radio works, but keeps blowing one of the 20amp fuses on amp, and ideas of what happened,
Old 31st August 2009, 07:25 PM   #2
If it only blows the fuse after the remote voltage is applied, you likely have shorted output transistors (large transistors clamped to the heatsink near the large blue resistors) in one channel.
With your multimeter set to ohms, you should not read anything near 0 ohms when the probes are touched to the terminals of any individual transistor in any configuration. If any are shorted (~0 ohms between any 2 legs of any individual transistor), they will likely be shorted from leg 2 to leg 3 but you should check 1-2, 1-3 and 2-3.
If it appears that several are shorted, you'll need to remove all that appear shorted from the board and check them individually. If you find only 1 shorted in a group of parallel-connected transistors, you can reinstall the ones that are not shorted to see if the amp will power up. If it does, you need to replace all in that group of parallel transistors.
Lanzar VIBE 530 1 bad channel turbosundance Car Audio 14 31st August 2009 06:25 PM
Holey Brace and other vibe quellers 901Fixer Multi-Way 5 24th June 2009 09:45 PM
Lanzar vibe 430 intermittent channel n2audio Car Audio 5 22nd August 2007 05:04 AM
Lanzar Vibe 1800D Problem, please help! manni Car Audio 3 13th October 2006 10:20 PM
Lanzar Vibe 531 amp question. MyNameIsJake Car Audio 6 24th September 2006 01:37 AM
Page generated in 0.06083 seconds (73.57% PHP - 26.43% MySQL) with 10 queries
