I just picked up an Orion 150R and a previous owner removed the speaker and power posts from the PCB and soldered wires. I'm looking to return it to stock.
I looked at another amp and found they are made by WECO. I could not find any replacements on the WECO website. Any idea where I can pick these up? EDIT: I think the speaker is this part number: TYPE 374-STG And the power plug is this part number: TYPE 377-STG Last edited by ECM; 31st August 2009 at 01:09 PM. |
#2 |
Isn't WECO an acronym for Western Electric -- the former manufacturing arm of Ma Bell?
I have WECO jacks on one of my HP synthesizers -- I think it's the 150 ohm output. |
#3 |
Check Ebay they sell them there all the time. Weco has minimum order limits in place on these older plugs and you will need to buy 1000's to get them to make a production run, and then you must wait till they have been made also...
#4 |
You can always buy a WECO to BNC cable or connector -- and I bought mine, a Pomona, on EBay as suggested.
#5 |
I'm looking for the part that goes on the PCB, not the part that you hook up the outputs to. The actual metal post that is soldered in the PCB is missing - all of them.
I've found the part number, just cannot order them. Another option is to find a donor amp and remove the posts from it, but it seems like an expensive proposition. |
#6 | |
Yeah killing another amp for these pins is kind of expensive, I agree. Have you seen the Weco price for these pins ? Ordering out of date connectors like this requires a production run, and a minimum order to be placed and paid for in advance most likely. I have friends that bought the speaker plugs and they shared their buying adventure with me. So this is why I know anything about the purchase of these devices. The gold plating alone would be pretty hefty about now with the elevated gold prices currently...that's why the ones on epay are mostly polished steel and not gold plated like the originals. And Weco is a company name that is used to define a entire product line of quick disconnect power and speaker terminals used in car audio for years by such names as PPI/Orion/Infinity/, and many others. The line includes PCB mounted screw terminals and just about everything in between. So the term Weco which was used by Infinity in its literature is a generic term that links you on the net to the makers of these things long, long ago. There may be no low cost alternative unless someone has some spare in their parts bins, or on dead amps. Even I keep the ones I have for clients restoration work needs...You just can't find them anymore, just like Phoenix Gold terminals for early MS amps they made. Last I saw they were going as high as $100.00 a set, and they get broken in shipping so easily..... |
#7 |
I did find that "future electronics" online sells them, but they don't have any in stock. I may try and place an order anyway and see what happens. I really hate when amps get butchered this way and really want it back to stock.
On the weco website they have them listed. I may have to do an inquiry or ask for samples if they don't deal in small numbers. |
#8 |
Seems these parts are hard to find. Who makes the absolutely cheapest amps that use these connectors? It looks like I'm going to have to steal the posts from another amp.
If anyone has a busted amp please let me know! |
#9 |
I was thinking about using more modern connectors for my PPIs myself. there is more than sufficent room. I'll just bend a new side before doing so.
#10 | |
Orion, PPI, Infinity, Directed, ADS,....And there are a few others but I am fading this morning for some reason. There was a guy on epay that was selling a bunch of old PPI/Orion gear by the name of Patrick...And his selling name was robotunderground, but I think he has changed to it to something off beat like juicyrobot or something like that, < as I said Off beat > He may be able to help you as I recall he bought all of the PPI/Orion/ADS inventory at the bankruptcy sale. I bought a few incomplete boards off him myself, and they had Weco pins already loaded on them... Good luck on your search |
| Can I use 4-pin Molex connector as speaker connector? | MikeHunt79 | Everything Else | 5 | 3rd June 2009 07:21 PM |
| Orion speaker plug | ECM | Car Audio | 11 | 23rd August 2008 06:05 AM |
| weco 352 transformer | henryp | Parts | 0 | 12th January 2007 02:19 AM |
| PPI Speaker Connector | Rickdogg | Car Audio | 2 | 10th September 2006 08:15 PM |
| Finished my DIY Copper foil speaker cable, what connector to use? | Guijs | Everything Else | 4 | 19th October 2005 10:31 PM |
| Page generated in 0.10807 seconds (81.26% PHP - 18.74% MySQL) with 10 queries |
