what's the odds of zed having or been able to make a new transformer for my zeus?
#2 |
good luck on that one!
The problem isn't Zed but rather vari-power is registered Hifonics(Now Maxxosonics). That transformer is what did the magic. If Hifonics got wind that someone @Zed corp. was duplicating a proprietary design lets just say it wouldnt be pretty. On a personal level he may share info on how to make one. If all else fails I'm sure it could be rewound,and reversed engineeried yourself. ORION FOR LIFE
...............I Hear in color................. |
#3 |
there's no way i could make one, looks like the amp is scrap then, deffo a transformer issue, when i wriggle it the music gets louder for a second and then the amp goes into protection after about 5 seconds
#4 |
When the amp is playing what power-supply voltage are you getting across the output transistors?
Need to make sure amp is operating correctly and not having any other issues,like stuck in (High,Med.,Low)power modes.
#5 |
You have mail Marko.....C
#6 | |
it has sound on at least one channel (need to check both) but soon as you turn it up it goes into protection... |
#7 |
If you want to measure the rail voltage on the outputs, place the black probe on one of the non-bridging speaker terminals and the other probe on the center leg of the outputs. One side will have positive voltage. The other side of the amp will have negative voltage. The voltages will be approximately the same unless one of the rail switching transistors is defective.
Is the shield ground on the RCA jacks intact? If you don't know, place one probe on a non-bridging speaker terminal and the other probe on the RCA shield (no RCAs plugged in). Push back gently on the jacks while doing this. You should read ~0 ohms.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#8 |
rca shield has 0 ohms..
just measured rail voltage and at 1st i had 16.43v and -17.40v on the other side, then (typically) the amp went into some kind of protection and the voltage just went very random? strange. |
#9 |
If you connect speakers to the amp, does it make any strange noises just before it goes into protect?
#10 |
not really, just turns off with maybe a very small hiss but nothing of significance..
| Page generated in 0.10648 seconds (77.54% PHP - 22.46% MySQL) with 9 queries |
