Dc offset on usamps axtu 1000
thank you,i feel strange with the relay,it works too soon,after i turned on the amp,only 2 or 3 seconds the relay starts to work,it placed after the capacitor from the tubes to transistor circuit (amplifier circuit)
I know this is an old thread but I have just gone through adjusting the DC offset on a USAMPS AX TU1000C.
Greg at U.S. Amps got me squared away, he was very approachable and helpful.
A multi-meter, screwdriver and allen-wrench did the job.
I powered up the amp with no input or load and let it sit for 20 minutes.
I adjusted the pots (small increments) while monitoring the offset to <100mV at the speaker terminals.
The pic is of my amp, pots circled.
If your board is different and/or you need direction I highly recommend Greg.
No more turn-off pop :D
