Go Back   Home > Forums > General Interest > Car Audio
Old 9th August 2009, 12:10 PM   #1
Default Any flaws in my box design?
Ok I'm buying two Alpine Type R 12s D4 subs soon and I designed the box. Below is a link to a Png/Image of what I have designed using the RE Enclosure Calculator, I've never made a subwoofer box before so I need to be sure I've done it right
Also how will Two Alpines @ 1ohm powered by 1200 watt RMS sound in that box?
Thanks again guys.
Link: http://img5.imageshack.us/img5/3671/filep.png
P.S. Ignore the attachment, I tried uploading my Box Specs and It said it was too large, then I couldnt even remove the attachment URL so I made a 1pxby1px image in paint and uploaded that instead.
File Type: png ignore.png (142 Bytes, 48 views)
Old 9th August 2009, 07:44 PM   #2
spooney is offline spooney  United States
The box looks to be ok.Port area is consistent with the enclosure volume you have although I personally go a little smaller with the port area just because it helps keep the length of the port down and thus makes the overall enclosure a little smaller.Tuning frequency is good too.I usually shoot for 35hz with my ported enclosures as well. Your box specs look right on with what most people are doing in car audio these days. No real way to tell how it will sound because that has a lot to do with your car as well but I think it will be fine.I surely don't think it will sound terrible by any means
Old 10th August 2009, 01:53 AM   #3
looks nice good work. let me ask you with what kind of program you did it?
Old 10th August 2009, 01:24 PM   #4
Thanks guys, BTW I send you a email for what program I used.
Old 10th August 2009, 08:39 PM   #5
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
It's an RE online calculator, you can use same one on my page, or even download it
About box... 2c/f per sub is good, port is also perfect, in the end you will end up with probably little less then 4c/f and tuning 36-37Hz
Its good! now get to and lets see it
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Collated Design Criteria/dimensions for Ariel ML-TL Design talsius Full Range 1 13th October 2011 05:28 AM
Wilson Watt Puppy Clone Design - Design Review Please soundengine355 Multi-Way 8 15th August 2008 02:07 PM
4th order bandpass, wheel well design :) (design inside) TWOJZ Car Audio 28 13th January 2008 02:56 PM
Page generated in 0.08455 seconds (80.70% PHP - 19.30% MySQL) with 11 queries
