Hello
Have a kicker 352xi that is dead have change the irfz44 and the capatasators in the proses i burnd r15 and canīt see the value. Pleas help me. |
#2 |
What components does the resistor connect to? If it connects to the left leg of one of the Z44s, it will be the same value as the one connected to the other Z44.
If it ain't broke Don't fix it |
#3 |
Hello
It is connecket to tl494cn (u01) on leg 8,12 and 11 and a transistor The ic donīt get any power to start. The resistor is to the signal fron the radio. |
#4 |
In many of the older kicker amps, they use an NPN transistor to drive a PNP transistor. The PNP transistor delivered B+ to those pins of the IC via a resistor (between 33 and 100 ohms).
The PNP transistor (possibly a 2SA1023) would have the pin configuration of ECB (Emitter, Collector, Base). The transistor would have B+ voltage on the emitter. The base would be driven towards ground when remote voltage was applied. The collector would deliver voltage to the resistor when the base was driven towards ground. If you need a sub for the PNP transistor, a BD140 should work. I'd probably use a 33 ohm resistor unless you can confirm the value of the original. The ones that used the 100 ohm resistor generally had a zener diode connected from the resistor (also pins 8 and 11) to chassis ground.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#5 |
thacks for the quick anser. I vill try to hange it to a 33ohm.
| Which resistor type for emitter resistor? | sajti | Parts | 25 | 8th April 2009 06:12 AM |
| polk componets & Kicker 352xi amp Failure | skooter | Car Audio | 9 | 4th September 2008 10:00 PM |
| kicker 352xi resistors across output burned, what resistance? | ppia600 | Car Audio | 2 | 19th August 2007 02:45 AM |
| Kicker: KX vs. SX | NaftaliG | Car Audio | 0 | 11th December 2004 08:21 PM |
| screen-plate resistor and grid leak resistor | metebalci | Tubes / Valves | 4 | 26th February 2004 03:18 AM |
| Page generated in 0.07720 seconds (79.32% PHP - 20.68% MySQL) with 11 queries |
