#11 |
That is simply beautiful, and there is still room for occupants. Do you run a subwoofer as well or are the two door woofers enough? What frequency do you cross the two woofers and the MTM unit over?
#12 |
Impressive
![]() I have a love-hate relationship with kickpods...I love the way they sound, but if I'm driving any significant distance, my foot just naturally wants to go to that dead pedal space. Maybe someday when I can dedicate a vehicle just to audio projects.
Jim J. |
#13 |
Nice work. I'm sure it sounds great!
So would the midrange be equivalent to the 4" Morel, or are they smaller?
Tim |
#14 |
Neat project, I'd be wanting to try an IB sub for sure. Anyway just thought I'd suggest some guys are talking about coax, but not auto made coax. They are running the ones from seas, hi-vi, and the like.
A BP box could work, but without large midrange/midbass they have such a narrow band. You can run something like an icepower alpine pdx 4ch its all class d takes less power. Otherwise my old rule is go larger drivers for more sound. When I was installing in boats (offshore vees) I'd always try for two pair of 6x9 to start with and 7x10 were better yet....could get away without subs with four of those. Open air sound is different than closed car, no doubt about it. (lot of them didn't want subs due to extra weight and lack of room.) It sounded a lot like a very good dj/sound system in a smaller bar. |
#15 | ||
The problem with this car (85 929 (Cosmo) Coupe are that the gas tank steals as much luggage space in the trunk as a large sub box would do, so a quarter panel installation migth be a solution. X over betwin tweets and mids are 3200hz/18db oct and betwin mids and woofers are 200hz/18db oct I use a Alpine CVA-1000 with a PRA-H400, so i have on screen adjustment for x over frequenzies and time correction The speakers are powered with a RF 400x4 wich feeds the tweets 50Wrms each and the mids 50Wrms each (100W a pair due too 2ohm load) The woofers are powered with a RF 200x2 @ 100Wrms each (200Wrms a pair due too 2 ohm load) Quote:
![]() Inner baffle with cutout for mids ![]() Mids are sandwiched betwin inner and outer baffle (grills are sligthly smaller than the mids themselves) Last edited by FE3T; 22nd September 2009 at 11:26 PM. |
#16 | ||
4" midrange with 2" voice coils? I assume they easily deal with 50W each. Quote:
With 6" Morel woofers, you could bypass the mids and use a stout tweeter that can reach 2kHz or so. Those woofers are good down to about 50Hz and handle (also require) hefty amounts of power. Or the 4" Morels in MTM with a larger woofer or two would be reasonable.
Tim |
| 4 ohm or 8 ohm woofer in 2 way | mmgando | Multi-Way | 0 | 4th December 2007 07:14 AM |
| What can I do with this woofer? | Bricolo | Multi-Way | 5 | 1st April 2004 09:37 PM |
| diy sub-woofer | takashi | Subwoofers | 3 | 19th August 2003 09:16 PM |
| the best mid-woofer? | joz | Multi-Way | 4 | 19th March 2003 08:19 AM |
| Qts of Push-pull woofer and Compound Woofer System... | haggy | Multi-Way | 1 | 13th December 2001 01:30 AM |
| Page generated in 0.09122 seconds (81.29% PHP - 18.71% MySQL) with 10 queries |
