Need to know a missing part in an amplifier?
Old 5th August 2009, 03:17 AM   #1
A-Money605 is offline A-Money605  United States
Default Need to know a missing part in an amplifier?
I recently got an amp from a friend for free cuz he said it was missing an internal part but the problem is i dont know what the part is, so cud someone maybe help me out and tell me what it is, and where i might be able to get one
The amp is a Soundstream Picasso PCX1500D, and the part thats missing is labeled L304, there is a circle plate where it sits that is about the size of a 50 cne tpiece and there re 4 solder points where the wire posts would go, but any help would be appreciated
Thank You
Old 5th August 2009, 03:28 AM   #2
I Am An Idiot is offline I Am An Idiot  United States
The missing part is the inductor that removes the high frequency ripple from the power supply. There are actually 2 conductors around the single core. One is for the positive voltage and the other is for the negative voltage.
If it ain't broke Don't fix it
Old 5th August 2009, 05:18 AM   #3
Perry Babin is offline Perry Babin  United States
You can jump the inductor out for low power testing. With the way the board is oriented in the first photo, you would jump from the top terminal to the bottom terminal. I'd suggest using fused jumper wires (5a fuse max). The fuses will help protect the amp if your board is different from the ones I have here.
The inductors vary but for the last one I had to rewind, each bundle of wires had six 21g wires. There were 14 turns for each winding (1 winding = six 21g wires). They wrap around the core as shown in the attached photo (notice that one comes from under the core and the other goes over the top before going into the board). On the opposite side of the core, the red comes from the top, down the outside of the core and then into the board. The green winding comes from under the core and into the board.
You can get a suitable core (or cores - 2 stacked) from cwsbytemark.com. Email them for core suggestions (T-130-26?). The inductance for each winding is 50uH.
Of course, if you can find a donor amp or can get one from soundstream, that would make things much simpler.
Old 5th August 2009, 05:24 AM   #4
If you do wind one yourself, make sure you keep the windings tight at the top and bottom of the cores. If it is too high it will rub the inside of the bottom cover. And for a donor amp. It appears to be the same board as a Planet Audio product. This may be easier to find than your particular amp.
Old 5th August 2009, 05:43 AM   #5
Looking through some amps I have here, I found a SS PCA2000D. It has a single wire for each winding. 11 turns each. The diameter appears to indicate that it's 13.5g. If you find that the wire stubs in the board are a single strand, your amp may have had an inductor like this one.
Old 5th August 2009, 03:22 PM   #6
ok im kind of dumb with technical terms and part names lol i just know how to install amps, but the fused jumper wire thing would that work and how exactly would you do that, and the other thing is i got 2 other amps with broken parts i just dont know wat i would be looking for in it
Old 5th August 2009, 03:22 PM   #7
and perry babin yea it looks like one thick strand on each post
Old 5th August 2009, 05:02 PM   #8
Use an inline fuse holder as a jumper wire.
Without knowing what the other amps are, I can't tell you if anything in them would work
Old 5th August 2009, 10:15 PM   #9
like i said parts of this i dont exactly understand i would need 2 jumper wires? but where would i attach them and would those be in place of the inductors
Old 5th August 2009, 11:09 PM   #10
See attached.
Need to know a missing part in an amplifier?Hide this!Advertise here!
Wanted ~ Lowther LL26 Amplifier ~ ***Excellent Price ***paid or swap/part ex TheMooN Swap Meet 0 11th October 2008 08:19 AM
what part can take the place of ST part VB408B completely peterchen88 Parts 0 8th September 2007 05:45 AM
Trying to figure out what a part is in an amplifier. Beat_Dominator Parts 16 22nd July 2007 10:02 AM
Matching Aleph input devices as a part of the complete amplifier? BrianGT Pass Labs 5 28th March 2002 06:11 PM
Copyright ©1999-2017 diyAudio
